Salt is here... blah. Should I undercoat?
Old Nov 12, 2013 | 06:47 AM
beastmode's Avatar
Import Moderator
Default Salt is here... blah. Should I undercoat?
So today was pretty much the first day of snow that we've gotten in Western PA (that I know of). Made it the entire way to work with no salt... pull in the parking lot and boom you'd think it was ****** snowmageddon
I hadn't given much thought to undercoating but the one guy I was working with said he has one of the local undercoat jobs. Anyone have any experience with it and if so what are your thoughts and impressions?
I intend to keep this truck as my dd for a few years and I'd like to keep the underneath as clean as possible.
Old Nov 12, 2013 | 08:41 AM
03sierraslt's Avatar
Ya undercoat it so when the next owner gets it In a couple months it's done.
Old Nov 12, 2013 | 09:17 AM
fortplainman's Avatar
LOL.
if you want to do it yourself look into KBS Coatings. bought stuff for my 10bolt but will do it this spring. not sure if you dont do it yourself whats out there though.
Old Nov 12, 2013 | 10:19 AM
GREENSIERRA's Avatar
I undercoat my truck twice a year, I do it in fall before the salt hits and then in spring when the streets are clean.
I use rubberized undercoating
Old Nov 12, 2013 | 10:29 AM
silverado6.2's Avatar
Rubberized undercoating is ok if the surface is prepared correctly. If it's not, the undercoating will eventually crack and separate from the metal and provide a place to hold water/mud and salt. The end result years later is usually a rust hole that is being hidden behind a thick layer of rubber. Several manufacturers will not honor a corrosion warranty if the rubberized stuff is used. The better coatings remain soft like cosmoline but do nothing as far as sound deadening or chip protection like the rubberized stuff.
Old Nov 12, 2013 | 11:14 AM
I have been using rubberized undercoating since brand new on my truck and never had a problem.
I just go to the carwash and rinse the frame and spray it on
the truck is a 05
Old Nov 12, 2013 | 11:25 AM
the truck is a 05
At two coats per year I would suspect it's getting a little thick by now.
Old Mar 30, 2014 | 09:03 PM
TimDave217's Avatar
^^^ x2! thats a lot of undercoating on the frame now. wow!
Old Mar 30, 2014 | 09:07 PM
boomer71's Avatar
Yes undercoat would be a good idea, but be reminded it will add some weight also make sure to cover some sensors before applying it. I heard some people would spray some wd40 as their protection to salt. has anyone tried this?
Old Mar 30, 2014 | 09:15 PM
TIM Z's Avatar
11 sec. Truck Mod
I vote sell it after winter , wait ..........
