rollpan mounting???
Old Nov 4, 2006 | 12:39 PM
beastmode's Avatar
Import Moderator
Default rollpan mounting???
im sure this is a stupid question but how did you guys mount your roll pans on? when i had mine on my blue truck i just drilled holes into the part where the little roll pan lip sits onto the bed and pop riveted it on, which i must say was a very shitty way to do it, it looked really stupid. so i figure that cant be the way all you guys are doing it?
Old Nov 6, 2006 | 01:58 PM
beastmode's Avatar
Import Moderator
lol anybody??
Old Nov 6, 2006 | 02:38 PM
JT-bo's Avatar
on my s-10 I just used the screws and caps that came with the kit and put the black caps the over the screw heads under the tailgate. they fell off after a few hundred miles though! haha
same process to hold the bottom tabs to the side of the bed.
Old Nov 6, 2006 | 04:39 PM
beastmode's Avatar
Import Moderator
yea like i didnt even get any screws or caps or anything w/mine, w/e guess ill just do it that way, just wasnt sure if there was a better way. wat sux is the silverado bedside tabs are like 1/8" wide so there hard to get anythign into.
Old Nov 6, 2006 | 07:42 PM
02BlueStepside's Avatar
Mine mounted the same way, stainless screws in the bottom of the bed, behind the tailgate. Then it had a bracket for each side where you attached the bedsides to the pan.
Old Nov 6, 2006 | 09:10 PM
beastmode's Avatar
Import Moderator
hmm ima have to try to find that bracket, i cant believe mine didnt come w/ anything but the pan
Old Nov 7, 2006 | 03:12 PM
Those side brackets may just be for the stepside beds.
Old Nov 7, 2006 | 03:14 PM
silver-mod-o's Avatar
Hunt&Fisherator
I screwed mine into the back of the bed behind the 'gate too... and had to fab up some straps for the ends.
Old Nov 7, 2006 | 03:33 PM
beastmode's Avatar
Import Moderator
yea cause i put bout 5 pop rivets in where you guys are talkin buot under the gate and one in on each side of that little lip on the inside of the lower quarter of the bed, and it just seemed like everytime i shut my gate or something my roll pan would shake back and forth like it wasnt mounted enough, o well ill just put a billion screws in lol
nabozny21
Oct 17, 2015 07:47 PM
thewrx
Oct 6, 2015 10:59 AM
KINGCYCLES
Oct 2, 2015 10:21 AM
old motorhead
Sep 29, 2015 08:22 PM
DrX
Sep 29, 2015 04:31 AM
