removng door trim????
Old Jul 27, 2012 | 05:37 AM
gsxrluke's Avatar
Exclamation removng door trim????
2008 chevy 1500 lt. how do u remove the thick plastic door trim??? i know how to take the badges off by heating them but not sure about the door trim. i dont want to mess up the paint. are they just stuck on?
Old Jul 27, 2012 | 07:07 PM
TIM Z's Avatar
11 sec. Truck Mod
Just take your time and pull slowly,
I like to start with a plastic body filler paddle to work behind the trim and help pry it up, just pull easy, then your thumb and elbow grease, and that orange goo gone will get rid of the adhesive ,
Good luck !
Old Jul 31, 2012 | 09:30 PM
xdmikey's Avatar
Default Plastic body filler paddle
Where to buy?
I washed the beast and decided that I should join the pack and streamline the ride. And it looks loose in a few places!
I remember on my '92 sportbed, I peeled an upper corner of the decal on the tailgate then clamped a vicegrip on it and watched it peel off on its own.
Old Aug 1, 2012 | 12:31 AM
abey15's Avatar
On my 06 i slowly worked on a corner till i had a start in it. Then slowly pull it off. If u park it in the hot sun it will take most of the adhesive with the molding! gl.
Old Aug 3, 2012 | 11:57 PM
1bad2k's Avatar
Just let the truck sit out in the sun for a few hours, grab a corner and slowly pull. Do yourself a huge favor and buy an eraser wheel. Automotive grade goo gone works wonders as well. Be sure to clean thouroughly and apply a coat of protectant afterwards.
Old Aug 4, 2012 | 11:23 AM
bow tie guy's Avatar
use a hair dryer or move the heat gun carefully, it's easy to overheat with the heat gun
I used a huge plastic spatula litterally a 15 minute job with the eraser wheel
mine came mounted on a die grinder
for 25.00 bought it at an auto body supply/detail store
try TCP global through amazon 3m wheel looks to be better choice but the generic worked fine for me
now 47.00
Amazon Amazon
cheyenne383
Nov 13, 2015 09:24 AM
rumblebox
Oct 29, 2015 10:35 AM
BCraven1018
Oct 1, 2015 08:22 PM
RS/SS 4.8
Sep 17, 2015 09:17 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
