Removing center console
Old Feb 27, 2003 | 07:06 AM
2ksleeper's Avatar
Default Removing center console
Does anyone know how to remove the center console in a 2000 x-cab & if so could you please explain. The reason being the front part of my console has worked its way loose & is starting to rattle, which is driving me nuts. If I can get the darn thing out I think I can fix the rattle.
Old Feb 27, 2003 | 07:22 AM
IM LOWR's Avatar
Default Re: Removing center console
Not sure if the same goes for EC but in my SC with 40/20/40 buckets the middle seat comes out after the two outer seats are out. the brackets are stacked on one another. If you just have a console that is not a seat I am not sure. Have you checked for bolts holding it down inside the bottom of the console under the storage areas?
Old Feb 27, 2003 | 08:14 AM
LarryE's Avatar
there should be three screws at the bottom of the console just take them out and pull it off
dsbodley
Nov 14, 2015 09:46 PM
cheyenne383
Nov 13, 2015 09:24 AM
lukn4trbl355
Oct 21, 2015 11:19 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
Closer_2001
Sep 24, 2015 09:15 PM
