removed mouldings but now theres a problem....
Old Jun 17, 2004 | 05:10 PM
dabflyboy's Avatar
Default removed mouldings but now theres a problem....
i removed my mouldings on my 2000 silverado and now theres this hair sized glue line all around the outer portion of where the glue tape was. i cant get the damn thing off for the life of me. ive tried scraping it with my fingernail, 3M adhesive remover and another brand as well. all im getting it a "squeaky clean" sound when i rub the stuff on. what else can be done...besides sanding and waxing?
Old Jun 17, 2004 | 05:16 PM
nekkid_hill_billy's Avatar
bug and tar remover id say would do it, rubbing alcohol works on sticker glue so it ma ywork also
Old Jun 17, 2004 | 05:27 PM
ZaneO's Avatar
Denatured alcohol or 3M Prep Sol
Old Jun 17, 2004 | 07:17 PM
WaitinToDrag's Avatar
heat gun or hair dryer...warm up the glue....an adhesive remover and some elbow grease
Old Jun 17, 2004 | 09:13 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
There is this stuff that you can get at Home Depot called Goof Off. I haven't found anything yet that it can't get off.
Old Jun 17, 2004 | 10:08 PM
dabflyboy's Avatar
ok cool. thanks y'all!
Old Jun 17, 2004 | 10:18 PM
vortec327's Avatar
you took the words right out of my mouth.
Old Jun 18, 2004 | 01:01 PM
Ryan23silverado's Avatar
Elbow grease! Be careful too. I put a coat of bug and tar around the area just in case anything slipped while I was working it would have some protection against a scratch.
I found the 3M Adhesive remover the best. It crystalized that gray glue/foam stuff within about 40 seconds. Once it is crystalized, you can just scrape it off with a plastic razor. Then clean everything up with bug and tar remover.
I think this may have come too late, but I hope everything is working out well. **It takes time.
Old Jun 18, 2004 | 02:01 PM
clay bar - it will lift up any contaminates off the paint - use a spray detailer when using the bar
but goof off and goo be gone works very well
Old Jun 18, 2004 | 03:24 PM
niwtsol's Avatar
when i took my emblems off i used claybar and goo be gone. worked very well except for some scratches i got from using a metal paint stripper.
