remove the molding
Old 06-08-2006, 01:51 AM
Default remove the molding
alright, i am debadging tomorrow and i want to remove the molding while im at it, is it stuck double-sided taped on there or does it have plastic pins that stick into small holes in the body panels? i dont want to take off the molding if its just gonna have 4 or 6 holes under it
Old 06-08-2006, 05:11 AM
11 Second Truck Club
Breeze's Avatar
It has double sided tape on it.
Old 06-08-2006, 10:13 AM
thanks for the info
Old 06-08-2006, 10:24 AM
Formerly 08_gmc_slt-08/20/2010
10RamSport's Avatar
I recommend using some strong fishing line or wire and run it behind the molding like you would floss your teeth. Helps cut throught the tape and keeps most of it on the molding and not on you truck so that when they are off, your cleanup of the residue is much easier!
Old 06-08-2006, 11:16 AM
jakebdb56's Avatar
is it easy to get the tape off the body once you take the moulding off? I know that you can't really use nail polish remover (works awesome for tape residue) any suggestions? or does it just peel off?
Old 06-08-2006, 11:26 AM
Resident Retard
BlackGMC's Avatar
Get some Goo Gone from home depot, that is what i used.
Old 06-08-2006, 11:36 AM
ballagh's Avatar
I just did mine last week. Very Important - make sure you leave it sitting out in the sun for a couple of hours before when you do it, makes it a lot easier to get off. . Mine just peeled right off with nothing but my fingers, no residue either. I did the driver side at lunch and the passanger side after work. My truck is brand new though so I'm sure that helped a lot!
Old 06-08-2006, 12:27 PM
If you can't have it in the sun for that long, I just use a hairdryer for a little bit on it to get it loose.
Old 06-08-2006, 06:00 PM
jakebdb56's Avatar
yeah i just got mine about a month or so ago, should come off easily. thanks guys
Old 06-09-2006, 12:23 AM
i plan on trying to remove all the badges and molding about noon friday. all the tape glue should be good and melty by then! hopefully this isnt too much of a pain, ive got a roll orf dental floss, some thin string, a bottle of goo gone and fingers willing to get blistered
Quick Reply: remove the molding
