Radiator Cover
Old May 22, 2005 | 11:00 AM
SSlow 4.8's Avatar
Default Radiator Cover
Anyone know where I could get a new one, I looked on GMpartsdirect.com but not sure what they call it. Its the plastic piece above the radiator which is mounted on metal and is in plain view. It comes apart with 6 or so of those plastic push pins which also hold the wheel well plastic togetther...
A lot of ppl paint them or put decals on them... im just looking for a new one so i can paint it bc my original is pretty messed up and mangled.
Old May 22, 2005 | 11:43 AM
Coban's Avatar
if you are talking about the fan shroud then anyone that has swtiched to e-fans would probably get rid of theirs. Otherwise, try to look for fan shroud.
Old May 22, 2005 | 11:56 AM
SSlow 4.8's Avatar
no.. not fan shroud. The plastic piece that is above the radiator
Old May 22, 2005 | 09:40 PM
budhayes3's Avatar
PT's Slowest Truck
I know what you're talking about, not sure what they call it though. Radiator upper garnish? shield? valance? cover? Could try a dealer, shouldn't be that expensive...maybe you could talk them into giving you the part number. Or check a junk yard...not sure about the junk yards by where you live, but I couldn't find a part for anything newer than an 88 last time I went.
Old May 22, 2005 | 09:45 PM
budhayes3's Avatar
PT's Slowest Truck
This part, with the serp belt routing scematics and the other 2 lables
Old May 22, 2005 | 10:03 PM
jlwz71's Avatar
15081999 baffle was the old part number
Old May 22, 2005 | 11:17 PM
SSlow 4.8's Avatar
hmm, i could check the local junk yard... where are you searching for that part number jlwz71? Gmpartsdirect?
Old May 23, 2005 | 04:59 AM
jlwz71's Avatar
I got it from an old crash book I have.
Old May 23, 2005 | 10:57 AM
jksz71's Avatar
Try 15171404 that should work
Gadgetized
Oct 22, 2015 09:06 AM
gmcyukon
Oct 5, 2015 06:20 AM
gmcyukon
Oct 3, 2015 11:03 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
tim wellington
Sep 29, 2015 10:17 PM
