Problem after 03 Tails
Old Feb 18, 2003 | 07:57 AM
LarryE's Avatar
Default Problem after 03 Tails
Just got my 03 tails in and installed them on my 99...
Note: All the lights worked perfectly before installation.
All the lights checked out fine except the signal lights, they will not work now on either side OR the front, and even the indicator lights in the cluster will not light up
Note2: The hazard lights will still work.
From the tech manual on these trucks from what I can tell, the hazard and signals are on the same circuti, so shouldn't both not work.
I'm positive everything is plugged in tight on the power block under the bed, but I'm going to double check this evening (but if they wasn't none of the lights should work should they?)
<small>[ February 18, 2003, 09:14 AM: Message edited by: LarryE ]</small>
Old Feb 18, 2003 | 10:43 AM
Default Re: Problem after 03 Tails
Before reading Note2 I was just going to say check the fuses. I had a problem with fuses blowing out when I tryed to use APC's led bulbs. But that sounds odd. If the hazards work fine....then the turn signals should also. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Feb 18, 2003 | 11:09 AM
LarryE's Avatar
yea it's definitely strange, I got some fuses today to try after work... it sounds like in the Hayne's Manual that the fuse could still blow and just make the signals stop working...
Old Feb 18, 2003 | 11:16 AM
really slow truck's Avatar
yep, i would agree. it is most likely either a fuse. or the relay for your signals since there is a relay for the hazards and one for the turn signals
Old Feb 18, 2003 | 11:43 AM
LarryE's Avatar
really? Hayne's shows it being just one relay... their illustration is probably wrong though cause it would be strange to have both on one relay (but if anyone would do it that way it would be gm) lol
Old Feb 18, 2003 | 11:53 AM
lol, well i may make myself look like a moron...
when i worked at oriellys over the summer 99% of the cars had a different relay for hazards and blinkers. they did change alot of things when they started making these trucks though...
Old Mar 11, 2003 | 10:31 AM
JSmith's Avatar
I remember someone saying that you need new a harness when you upgrade to the new '03 tails.
Old Mar 21, 2003 | 10:14 PM
GMC SS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by JSmith:
<strong> I remember someone saying that you need new a harness when you upgrade to the new '03 tails. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have heard things like this too. I heard if you add fog lights to a truck that did not come equipped with them you had to go to the dealer to have the programming changed so they would work. My real job is with computers but that is a little over the edge! <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
