prep work?
Old Nov 2, 2008 | 04:47 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by aksz71
yup
Asumimg the out side surface is ok you should be able to wet sand with 600 use a cleaner/degreaser and paint it with what ever you have. some paints will require an adhession permoter so it will stick to the plastic.
95 bright teal's Avatar
is it the gold paint flaking or the plastic actually cracked?
Old Nov 2, 2008 | 05:05 PM
aksz71's Avatar
this is want it looks like over here on the right side about middle of the bow its in there but u rub a finger across it its all smooth
Old Nov 2, 2008 | 05:14 PM
1FastBrick's Avatar
Thumbs up
looks like a rock hit it and caused the crack... Like a windsheild... I guess if it shows up when you paint it you can just get a new emblem.... there cheap enough...
Old Nov 2, 2008 | 05:16 PM
aksz71's Avatar
so what u figure use 400 grit scuffing it and then wet sand with 600 and then paint?
Old Nov 2, 2008 | 05:19 PM
1FastBrick's Avatar
what are you painting it with??? professional stuff or just spray can??? you can go just 600 unless you have some divits you need to remove then start with 400 till there gone and clean up with 600
Old Nov 2, 2008 | 05:21 PM
aksz71's Avatar
spray can with my paint color from automotivepaint i think thats the name of website.
Old Nov 2, 2008 | 05:23 PM
aksz71's Avatar
automotivetouchup.com is were paint comin from
1FastBrick's Avatar
make sure you geta all the scratches out. spray can is thin... is it an enamel or laqure base??? you may need some adhesion promoter. they make it in spray can form
Old Nov 2, 2008 | 05:28 PM
1FastBrick's Avatar
They have it there... looks like 7.95 for 12 oz spray can.... I would recomend that first then the color. It Looks like its lauqer based... you would only put 1 coat of adhesion promoter wait for it to dry and then your color till your happy then clear coat it for a shiny durable finish....
