Power window conversion?
Old Aug 13, 2005 | 09:51 AM
Midnite_LS1's Avatar
Default Power window conversion?
I may be purchasing an 01 Chevy LS 4x4 that has manual windows...is this easy to convert to power? It already has power locks so I am thinking it may already have the wiring harness so I can just plug n' play...would this be correct or would I need a new PCM as well?
For those who have done it...can you list the parts that were needed for the swap so I can make sure I have everything before getting started...Thanks a million in advance!
Old Aug 13, 2005 | 10:45 AM
EDawg's Avatar
i did it on a 97. and used all factory parts. dash harness, lt + rt door harness, both regulators, both motors, all the switches, fuses, relays, door panels and trim. if you can not find this used it will be very$$$$$. i bought all new parts and it was well over $2000.00 good luck!!!
Old Aug 13, 2005 | 02:12 PM
I have a buddy who has a wrecked 00 silverado that has everything I would need...I just need to get over to his house to see if the interior color pieces will match
So are you saying that I DONT need a new PCM?
lucas287
31
Jan 12, 2021 06:18 AM
Corvette454l88
Sep 1, 2016 01:24 AM
Superman09
Sep 25, 2015 05:55 AM
MA$TER_E
Sep 9, 2015 03:14 PM
01 5.3
Sep 2, 2015 02:17 PM
