Polishing or buffing stainless question.
Old Feb 22, 2009 | 03:48 PM
KA41's Avatar
Default Polishing or buffing stainless question.
A friend of mine gave me a corsa exhaust tip but its very dirty and has a few light scratches on it. I would like to have it looking like new again. What would be the best way to get the light scratches out and polish it.
Thanks
Old Feb 22, 2009 | 03:50 PM
Mangled03gmc's Avatar
Baltimore Whore
Use a buffing wheel on a bench grinder.. Use alot of rouge.. Buff the **** out of it, try too keep all of the passes in the same direction.. Then use a good metal polish
Old Feb 22, 2009 | 07:21 PM
TG02Z71's Avatar
Make sure the rouge you have can cut steel but not too abrasive or you will lose some luster and have to go to a lighter grit compound.
Shouldn't really take too much work.
Old Feb 22, 2009 | 08:07 PM
KA41's Avatar
When you say keep all the passes in the same direction, do you mean make a pass, lift it off the wheel, go back to starting position and make another pass. What brand of rouge and polish do you recommend.
Old Feb 22, 2009 | 08:14 PM
Baltimore Whore
Yes, it will make the end result better. I am not sure what brand of rouge it is, but it is a white rouge. I have used ecp, flitz, never dull, all with about the same results.. Just have to take your time..
Old Feb 22, 2009 | 08:20 PM
2BFAST's Avatar
Time and patience is your friend
Old Feb 25, 2009 | 12:53 AM
OneQwikSS's Avatar
formerly 2004RST (changed 11/19/2012)
what about a very fine steel wool? i use it on my exhaust tips & no scratches at all comes out shiny as hell
Old Feb 25, 2009 | 08:34 AM
NHolds's Avatar
I use steel wool on mine too... depends on the condition of the finish. A picture would be good...
Old Feb 25, 2009 | 11:16 AM
KA41's Avatar
I will try and get pictures up tonight. Thanks for the input so far.
cheyenne383
Nov 13, 2015 09:24 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
blown02408
Oct 1, 2015 01:06 AM
Rockrz
Sep 29, 2015 09:07 AM
FlowmasterMufflers
Sep 11, 2015 03:32 PM
