Paint for Vinyl Door Panels
Old Jun 15, 2004 | 07:35 PM
SuthernFlames316's Avatar
Default Paint for Vinyl Door Panels
Im currently smoothing and painting all the plastic in my truck. Problem is you cant paint on the vinyl part of the door panels. I want to smooth it out and paint it the smae colors as my other stuff. Does anyone know how i can make the paint stick to the vinyl. I know they have vinyl paint, but they only have standard colors. Will i have to bondo over the entire panel then sand and paint. I need some info. Thanks.
Old Jun 15, 2004 | 07:38 PM
WaitinToDrag's Avatar
im doin the same thing and goin with fiberglass. where in louisiana are you..maybe i can recommend someone
Old Jun 15, 2004 | 09:35 PM
I'm wanting to do this to my Sierra for the dash trim as well as some pieces under the hood. What exactly are you doing to make the plastic smooth? Are you sanding or just using bondo or fiberglass to smooth everything?
Old Jun 16, 2004 | 12:29 AM
the best way to do this is to prep the plastic with some 330 remover. use 320grit paper and sand as much texture as you want out of it. the more teture you have the stronger the paint will hold, however, the smoother it is the better it looks. use a much primer as you can.
Old Jun 16, 2004 | 12:30 AM
are you putting fiberglass and resin over the vinyl? im from alexandria.
cheyenne383
Nov 13, 2015 09:24 AM
turbo6c3
Oct 5, 2015 06:11 PM
gmcyukon
Oct 3, 2015 11:03 PM
BCraven1018
Oct 1, 2015 08:22 PM
the owl
Sep 4, 2015 04:09 PM
