paint/dye that matches 99-07 classic charcoal gray interior
Yep SEM dye. Take a piece of the interior with you and test spry on it. You can use rubbing alcohol to remove it until you find the right match. Let it dry for a bit as it changes colors as it dries. I would wipe down the area with rubbing alcohol to clean it up before you apply the dye, don't freak out bc the alcohol will remove a lot of loose factory dye. The dash on my 01 Duramax basically completely came off and I redid almost the entire thing. It looked great, no one could ever tell I did it. Just make sure to tape off you windshield so you don't spend an hour cleaning it...
I know there are places that carry it, Maybe Auto Body/Paint Supply but when I called they didn't have the specific color I was looking for.
What color is it currently?
It will but if you need multiple coats you may need a second can.
The color can be kind of transparent.
When I spotted the repaired area in, I had to do the entire thing so it had an even finish and so that you didn't see a shadow around the area I touched up.
No. get at least 3 cans if you're doing the entire Dash. If you're going to spot touch up I still get two cans to leave yourself some room for practice. Remember to get 90% rubbing alcohol to clean up anything that you don't get right the first time. The stuff is pretty pretty giving if you don't let it dry hundred percent.
