new wheels 6 spoke armada wheels
Old Aug 18, 2012 | 08:07 PM
  #21
BLUES MAN's Avatar
The House is Rockin'
Hey by the way were did you get the clear corners?
Old Aug 18, 2012 | 08:52 PM
  #22
2000chevysilverado's Avatar
Got them on eBay were pretty cheap
Old Aug 18, 2012 | 08:58 PM
  #23
Originally Posted by black00chev
Just noticed you are keys/shackles/blocks. Here is my truck (just blocks removed) with 265/60-18s to give you a pretty good idea how it would look.
Looks good my truck seems like sittn lower than urs for some reason. Where did you get the front spliter on the air dam I can't find one
Old Aug 18, 2012 | 09:19 PM
  #24
black00chev's Avatar
Slowest turbo build ever!
Well I havent dont keys/shackles yet, just blocks. I have the shackles and might have some keys this coming week.
I got it from the dealer. I believe I used a 05 tahoe/suburban to get it. If you use an older model I think they only came in grey and not black.
Old Aug 18, 2012 | 09:47 PM
  #25
I'm using stock keys, my truck had small lift on it I bet 4x4 land gave me 2500 keys
Old Aug 18, 2012 | 09:51 PM
  #26
Yea Id say it seems like they did. luck you haha.
Old Aug 18, 2012 | 09:55 PM
  #27
im still gonna do a 2/4 drop after drivn in kc today my axle bottomed out against the brackets for the bump stops im goin to have to cut them off first
Old Aug 18, 2012 | 10:04 PM
  #28
You're talking about the rear bumpstop brackets right? They should be bolted in with 2 bolts each. Just unbolt them and and reuse two of the nuts and mount the bumpstops directly to the frame. There is a hole in the frame they mount directly to.
Old Aug 18, 2012 | 10:13 PM
  #29
Mine are pop revited in looks like hasnt been a issue everyday drivn but kc streets suck
Old Aug 18, 2012 | 10:34 PM
  #30
AKlowriderZ71's Avatar
11 Second Hall Moniter
They aren't riveted on. They kinda look like rivets, but they are studs going thru from the bottom. Reach up inside the frame rail, you'll find the nuts up there. They just unbolt.
Once the bracket is out, you can remount the jounce bumper directly to the frame. The hole (in the center) is already drilled in the frame from the factory. Easy Peasy.
