New tires: Does this look bad?
Old Oct 9, 2009 | 09:27 PM
04SilveradoMykk's Avatar
Default New tires: Does this look bad?
Hey Guys,
I was in desperate need of some new rear tires. And I just couldn't bring myself to keep buying the expensive Yokohama tires at the rate I keep burning through them.
So I decided to try a much less expensive tire, but I wanted something wider than the Yoko's too.
The fronts are my old Yokohama Parada Spec-X 265/40-22 tires (30.4" tall) The rears are the new Nexen Roadian HP's 285/35-22 (29.9" tall) at a whole $100 bucks less per tire.
Does it looks just absolutely ridiculous having a .5" shorter tire on the rear of the truck? Should I put the Nexens on front until the old Yokohama's are toast?
I like having the 285's in the back, should I just keep it this way until I change out the fronts too in a couple months?
Cheers ~Mykk
Old Oct 9, 2009 | 09:30 PM
charcoal03silvy's Avatar
I don't think its very noticeable unless you know what you're looking for.
Old Oct 9, 2009 | 09:32 PM
95 bright teal's Avatar
Its really hard to see, i say rock em till your ready to replace the fronts, thats the size i was looking at if i get 22's
Old Oct 9, 2009 | 09:33 PM
dlt76028's Avatar
not very noticeable...
Old Oct 9, 2009 | 09:45 PM
00ChevyScott's Avatar
Wearin' da big hat
I can't tell a difference.
Do those tires hook pretty good for a cheaper tire?
Old Oct 9, 2009 | 09:51 PM
StrokerAce03's Avatar
It makes the rake more prominent but other than that it looks ok to me.
Old Oct 9, 2009 | 10:06 PM
VMaxAZ's Avatar
Looks fine to me Mykk...
Old Oct 9, 2009 | 11:21 PM
TexasPainter's Avatar
Banned
i cant get past how ugly those wheels are....
Old Oct 9, 2009 | 11:37 PM
ButlerBoy's Avatar
It doesn't jump out at you but you can tell a little if you look for it. I personally don't like a side wall shorter then a 40 series on a 22 but that's just me. I say drive it as is and just do the front later.
Old Oct 10, 2009 | 01:15 AM
1quickRST's Avatar
I only could tell a difference after really staring at the truck. If i just glanced at the truck I don't think I would ever notice it. But if it bugs you, which is what really matters, then swap em.
