new HID's
Old Jun 1, 2010 | 01:26 AM
Default new HID's
just got a HID (low beam) kit for my 05 silvy from ebay wish i would of looked here first because now i see i should of went with ddm but anyway im getting a 8k 35w setup anybody have this or have any tips on where to locate the ballasts and i know something about having to switch some wires around not real clear on that if anybody is or knows about a good install video lmk please thanks!
Old Jun 1, 2010 | 06:40 AM
Preston129's Avatar
I have 6K and a different year truck, but your options are pretty limited for mounting options just by virtue of the short distance the wires off the bulb will go. There's usually room on a radiator support, or near the inner fender well.
Installation is pretty simple, there's only so many variables you can play with; two connectors off the bulb that have tabbed connectors, but on the ballast there's a 9006 style plug that has polarity, so if you connect the factory connector to it and the bulbs don't light, turn that connection around to switch the polarity and that usually solves the problem.
Go here and download the pdf; it's for 9006 style bulbs that you should have in your lows. https://www.ddmtuning.com/support/in...emid=2&nav=0,1
If you don't already, a relay kit and pulling the DRL fuses is advisable.
Texas5.3_1251
Mar 5, 2016 08:10 PM
the owl
Sep 4, 2015 04:09 PM
BIGD4504
Aug 19, 2015 07:57 PM
Bluchevypick
Aug 18, 2015 09:11 AM
Ammadien
Jul 22, 2015 08:50 PM
