Need Help Lower Ball Joint !!!!!
Old Sep 9, 2004 | 09:52 PM
mrb04's Avatar
Default Need Help Lower Ball Joint !!!!!
Need Help On Removing Lower Ball Joint From Control Arm Any Ideas Air Hammer Or Just Drill Rivit Head Off. 2004 Gmc Rcsb
Old Sep 10, 2004 | 08:10 AM
Drilling the rivets are B*tch
Cutting wheel ....
Plasma cutter ....
Old Sep 14, 2004 | 11:35 AM
70RallySport's Avatar
just buy a new control arm. the 150 bucks beats the hours of trying to beat the f'n thing out. just my info
Old Sep 14, 2004 | 11:44 AM
chevymec's Avatar
The lower ball joint presses out and presses in. might want to try to get the tool from a parts store to borrow for the job.
Old Sep 15, 2004 | 01:19 AM
5.3Vortec's Avatar
Banned
Where can you get new factory arms for $150?
Unless they changed some thing after 03 they are riveted to the lower control arm.
Old Sep 15, 2004 | 06:14 AM
chevymec's Avatar
Sorry, im use to replacing 4wd ball joints. I guess mrb04 has a 2wd .
Old Sep 15, 2004 | 08:26 PM
GREGGO's Avatar
There are 4 rivits that have to be either ground or drilled out. I ground the tops off mine and used a punch to knock them out. The replacement comes with 4 bolts. The uppers are a one piece unit. Ball and arm. They run about $170. The lower ball joint runs aout $75.
Sorry I'm 6 days late with an answer.
hodge9386
Oct 25, 2015 01:26 PM
Miguel199
Oct 16, 2015 08:04 PM
GMCtrk
Oct 5, 2015 11:18 AM
vmaxpro
Sep 28, 2015 11:10 AM
97_ek
Sep 23, 2015 09:16 PM
