Made my own Cal Tracs traction bars
Old Sep 4, 2008 | 06:48 PM
  #31
MorepowerTY's Avatar
I dont see any lock nuts in that picture... just wondering if you were using any?
I helped Dockrocker put a set of Caltracs on his '91 and the design is pretty simple..
I plan on making some when i get around to it...
Don't need any lock nuts. They will not spin, unless I unbolt them and spin them myself. Here's a set of the real Cal Tracs. There's none on these either. The only difference between mine and the real deal, is mine is custom made and painted. Plus, I can't find anything to use for the bushing thru the leaf spring at the front. Unless you guys might know of something? http://www.calvertracing.com/caltracs.html
Old Sep 4, 2008 | 08:35 PM
  #32
timmer1's Avatar
I was looking on your link at calvertracing.com and it appears at the bottom picture that it does have jam nuts on it. It looks like the bars are threaded and then there is the silver nut on the end. But if they don't spin, then I guess there is no need for them.
Old Sep 4, 2008 | 09:15 PM
  #33
nonnieselman's Avatar
They do have them..
The real Caltracs on the front have Right Hand Threads and the Rear of the bars are Left hand Threaded.. So in this case you need "Jam" nuts to keep them from moving..
I now see in yours, you used all Right Hand Threads? So yea you have to unbolt yours to Adjust.. The Caltracs are setup to be easier adjusted.
I plan on making a set cause my brother has a box full of the end links..
Ive found those Aluminum Bushings before... gimme a lil while and ill let you know where i found them at..
Old Sep 4, 2008 | 09:25 PM
  #34
Similar to these..
http://www.jegs.com/i/Competition%20.../2023/10002/-1
Old Sep 6, 2008 | 09:32 AM
  #35
You are correct. The real Cal Tracs do have the jamb nuts and the bars are threaded, and that would be the lock nut. My jamb nuts are welded to the bars, and I couldn't do the threaded bars, that's why I welded the jamb nuts. I guess I could have spent enough time on them and get inserts for the bars, just lazy I guess. Good enough for me though. As long as they work, that's all that matters to me anyway. The only time that I would really have to adjust them would be going to the track to get a stiffer ride. Thanks for the link on the bushings, a little pricey though. Maybe cause they are aluminum. I know of someone who could make some for me on a lath. According to another member, it's a real bitch getting the old ones out!! Prolly the toughest part of the job.
Terry
Old Sep 7, 2008 | 04:41 PM
  #36
stevenc's Avatar
When I build mine I will be using 1 1/2 .120 Wall DOM tubing and Hiem&Bung Combinations (to great the threaded tube).
http://www.bajaconcepts.com/bajaraci...go=rodends.cfm
place i found online with hiems and bungs. I generally buy them from my local supplier (i build custom suspensions and am obsessed with doing it right.)
Good job on what you did, I would have liked to see bungs welded in however.
Old Sep 7, 2008 | 06:21 PM
  #37
Those look very nice. But I didn't want to spend to much on them. I believe that the Cal Tracs are over priced already, that's why I made my own. The heim and bung kits look like top quality parts though. One of these days when my back gets better, I'll install mine. I don't plan on going to the track until late Oct. or Nov. anyway, but I know some of you want to see the results. So I'll try and install them when I can.
Terry
Old Sep 7, 2008 | 11:42 PM
  #38
chevytruckguy's Avatar
I think on those aluminum bushings, you'll have to press the old ones out and press the aluminum ones in. You could try machine shops or bearing suppliers for either bronze or steel bushing material for your setup. You can order specific sizes or cut them to fit.
carid
Oct 28, 2015 08:24 AM
BCraven1018
Sep 18, 2015 08:57 PM
TAPyvehc93
Sep 14, 2015 01:22 PM
