Lowering Questions
Old Mar 22, 2007 | 04:18 PM
greencountry05's Avatar
Default Lowering Questions
I've noticed that several of you guys have used 4/6 and 5/7 drops and I've been debating on which to go with. Any mods or problems I'm gonna' run into with either one? The ride height is stock at the moment with Toyo Proxes 285/60/18s.
Old Mar 22, 2007 | 05:30 PM
No real probs...requires you to notch the rear which doesnt hurt the truck...some people are picky though and wont do it
I honestly wouldnt do the 5/7 with Oklahoma roads...go with the 4/6
Old Mar 22, 2007 | 05:40 PM
Lol, good point. All the other 49 states have better roads than we do. I thought I may have to notch it, but I wasn't sure. Any guess on how I'm gonna' have to take out?
Old Mar 22, 2007 | 05:43 PM
What do you mean by take out?
A 4/6 uses control arms, c-notch, flipkit and it will need shocks
Old Mar 22, 2007 | 05:47 PM
02BlueStepside's Avatar
DJM 4/6 here
285/60/18 sounds like a big tire, as long as your backspacing is good you should be fine though.
Old Mar 22, 2007 | 06:32 PM
bgray's Avatar
TOTM: June 2007
4/6 Mcgaughty drop. 2" coil, 2" spindle, 6" cnotch, shock extenders, and c0notch. Beautiful kit, rides greats.
Old Mar 22, 2007 | 06:33 PM
My bad, I was referring to notching the frame.......
Old Mar 22, 2007 | 06:46 PM
Freedo's Avatar
Is your truck a regular cab or an ext cab? I used a Mcgaughy's 4/6 drop on mine; spindles, springs, flip kit, carrier bearing relocation bracket, and the c-notch was included with the flip kit. You can use the c-notch to mark your cut on the frame, which isn't bad. The one place where I had a problem was my lower balljoints wouldn't pop free, so after I got tired of screwing with them I just replaced them.
Old Mar 22, 2007 | 07:01 PM
I used a Sawzall...they way you dont chance tweaking the frame with a torch
Old Mar 22, 2007 | 07:59 PM
Derek @ EDO's Avatar
FormerVendor
i also used a side grinder with a cutting disc!
Worked well
BTW good thinking taking off the bed!
I wish i would have, talk about making things easier!!
