lower control arms vrs. lowering springs
Old Sep 7, 2003 | 10:30 AM
FILE's Avatar
Default lower control arms vrs. lowering springs
which would be better for a 2 inch front drop. After installing eather, will I need to align my front tires?
Old Sep 7, 2003 | 01:58 PM
MacADaYear's Avatar
Default Re: lower control arms vrs. lowering springs
I think if you get some nice springs your ride quality will be better but with control arms you keep the stock bouncy crap...
Old Sep 8, 2003 | 01:41 AM
sleepersilverado's Avatar
um well springs is the cheapest way. loke mack said though. i have lca's because i wanted to retain factory ride. aslo when ever you break the front end apart get it aligned. so it depends what you want from the drop. springs=more agressive little stiffer prob.
Old Sep 8, 2003 | 10:45 AM
BigKID's Avatar
If you are doing the job youself, springs will be a lot easier since you will not have to mess with the balljoints. But is like the others have said, it all depends on what kind of ride you want. IMO, the hotchkis springs are perfect for the front of the trucks, just the rear is a little stiff. With all the weight in the front of the trucks, a little stiffer spring will actually help out the ride.
Verz
Aug 21, 2015 06:40 PM
jacobrobertson2010
Aug 17, 2015 06:20 PM
Allgonoshow
Jul 29, 2015 04:21 PM
Kaldar
Jul 27, 2015 06:42 PM
Ketis
Jul 23, 2015 12:37 PM
