Looking for Light 18" wheel
Old Nov 15, 2008 | 03:16 PM
MassDenali's Avatar
Originally Posted by PSM
You are correct. I think they run more offset so the hub flange is closer to the outside of the wheel. Put a gmt900 wheel on a gmt800 truck and it tucks more. Put a gmt800 wheel on a gmt900 and it sticks out a bit further
Further out would be fine... the problem is the clearance between the tire and control arm at full rack is close as it is with a wider tire>>> but then again the 18" isnt 10" wide like 22s and 24s... I'll do some research on this. I had not looked before as I thought the NBS trucks (gmt900) had different lug pattern. Thanks guys... I'm going to look at the forged wheels... I never buy the cheapest of anything especially if I know it's the lowest quality- but I will have to weigh my budget against the quality.
Old Nov 15, 2008 | 04:49 PM
GMCtrk's Avatar
I run escalade 18's, they fit fine and weigh 28lbs each
Old Nov 15, 2008 | 06:13 PM
MassDenali's Avatar
I'm going to try to source some near me and see that they will fit over my brakes... found some for $600 with perfect tires... a little over 100 miles away, if I get the time I may check them out.
Corvette454l88
Sep 1, 2016 01:24 AM
Bluchevypick
Aug 18, 2015 09:11 AM
97aztecgt
Aug 13, 2015 02:11 PM
Ketis
Jul 23, 2015 12:37 PM
