LED Lights In
Old Feb 16, 2006 | 06:41 AM
agreif's Avatar
Default LED Lights In
Well I went with James' suggestion and got 3 6 bulb LEDs and 3 5 bulb LED's. I was able to take the stock bulbs out of their holders and reuse the holders for the LEDs. I set em up 2 ways, one with the 6 bulbs in the main part of the cluster (tach & speedo) with the 5's at the other gauges (voltage, gas, oil, temp) (Setup 1) and then I switched em (Setup 2). All 6 bulbs ran ~27 total from superbrightleds.com
Here's the original gauge.
Here's the setup with the 6 bulbs in the speedo/tach part
Here's the setup with the 5 bulbs in the speedo/tach part
I think the 5 in the speedo/tach looks the best and the most even.
Andrew
Old Feb 16, 2006 | 06:54 AM
BLACKHD01's Avatar
Looks good man. I went with the 5 also. I am looking to get some different needles. US Speedo has some needle kits but I can't decide on which ones to get. Let me know if you have any suggestions.
Old Feb 16, 2006 | 06:55 AM
CoonToot's Avatar
What a difference. That looks like time/money well spent.
Old Feb 16, 2006 | 12:30 PM
SBChvy's Avatar
Yeah the 5 bulb leds have a lot better spread-less hot spots. Looks really good, you gonna try some other stuff too?
Old Feb 16, 2006 | 12:47 PM
Hoay's Avatar
looks really good... wish i could do that.. i have a stinking '05
Old Feb 16, 2006 | 02:35 PM
stone150's Avatar
looks good, wnat to do it too, but i think after a while it would annoy me.
Old Feb 16, 2006 | 02:45 PM
agreif's Avatar
Well, now that I have those in there I would like to do at least the radio and the AC. I know the AC I need about six 5mm LED's for the **** backlight and a resistor to set the current ( I guess those aren't 74 LED's?). Do you just lay the lights where you want them when you solder the AC lights in? I guess 3mm lights for the little recirc lights, or is it that flat square one?
For the radio I'm not sure what's back there. Not sure if I can just solder in 10 replacement LED's or if I need resistors on all of those too. Of course if I went crazy I would do what you did and get an aftermarket with that sweet mounting plate. Not yet though.
Old Feb 16, 2006 | 03:51 PM
SBChvy's Avatar
Yeah you can use 3mm leds in the four buttons-and six 5mm leds in the **** section. You can't just lay the leds in because they project in a certain area. I (very carefully) drilled four more holes in the circuit board. The smd leds are for the window switches-I have no idea where to even look for them. O4BlackSilverado could probably help you with the radio-I beleive he did his. If you want to look at my hvac ill be back from college on March 5th, and I'm only about 20 min north of ALbany-I used to live in Colonie.
Old Feb 16, 2006 | 04:38 PM
agreif's Avatar
Cool, might take you up on that. I'm in Clifton Park.
AC needed resistors in each series(one for the ***** and one for the buttons)?
Old Feb 16, 2006 | 04:40 PM
duwem's Avatar
part number, price and supplier on the 5 bulb leds please, I know the other guys were runnin 4 bulbers with there setups
