i wanna drop it like its hot!
Old Dec 18, 2003 | 09:50 AM
  #21
onyx's Avatar
14 Second Truck Club
hey low2000... how much did your airbag kit run ya?... i figure since its air ride, its a real nice ride....
Old Dec 18, 2003 | 10:23 AM
  #22
slow4.8's Avatar
what about those "helper springs" that mount on top of the rear leaf springs. Could those maybe help the rear from bottoming out and increase towing capacity? Just a thought.
Old Dec 18, 2003 | 01:17 PM
  #23
LOW2000's Avatar
If I remember correctly it was about 4k in parts and I did all the work on it.
A couple things to note:
Your bed won't be bottoming out, its your axle hitting the frame.
If you do decide to go bags and someone tells you that you can lay fram on stock height tires without cutting into the bed floor, they are full of ****.
I havn't ridden in a stock silverado in so long that I can't really say anymore whether it rides better or not. I do know that weight in the bed DOES make it ride much better.
Depending on the width and offset of your tires (I run a 275/45/20 on a 20x8 5.5" backspacing) you may need to trim the rear fender lip to keep them from contacting during full suspension compression.
If you're going to be towing heavy loads, then air bags of some type are almost a must when lowered unless you want the rear end to squat. I've towed an RX7 on a u-haul trailer (between 5-6k lbs) and was able to lower the front bag pressure and raise the rear bag pressure so that even with that load it wasn't squatting in the rear.
Since you were obviously looking at my website, you may have noticed that my old truck had a 4/5 groundforce drop with no notch, so I know about regular lowering too if you decide to go that route.
Sorry so long.
Old Dec 18, 2003 | 01:31 PM
  #24
Originally Posted by v8
hey onyx go to www.aimindustry.com i just ordered my 2" springs for the front and hangers for the rear and shimms and bushings for the springs for 208 shipped and the good thing for you is there located in mesa AZ.
P.S all ready have the shackels incase you were wondering later, kevin
My .02
AIM SUCKS - I have never had good luck with that company - I you check with the better business bureau - I will blow you away....
My advise would be stick with a larger company,,, Belltech, Hotchiss, etc...
Just had very bad dealings.....
Old Dec 18, 2003 | 03:57 PM
  #25
Scream's Avatar
MOOBIES Moderator
Originally Posted by onyx_silverado
well sine i have a 2000 i shouldnt worry about that then... correct?
hmmm, just check your crossmember and see. If it hangs down a LOT (like in my pic) then you really should get one.
Go with the 4/6, you'll love it!!!
Old Dec 19, 2003 | 06:57 AM
  #26
onyx's Avatar
low2000, i have the same size tires as you, also my ss rims are 20x8.5 so i believe its the same backspacing... i wouldnt exactly know though....
Old Dec 19, 2003 | 01:01 PM
  #27
v8
17,16,15,14,13,12,11 Drvr
Thumbs up
hey onxy just received the lowering kit from AIM INDUTRYS not bad ordered it on monday and here today 2/4 drop $224 for the spings and hangers,shims,and rubbber boots for the spings later, kevin
Old Dec 19, 2003 | 01:28 PM
  #28
onyx's Avatar
well, i think i'm gonna go Hotchkis 2/4 drop... it was my first inclination... after seeing many pictures of different trucks w/ drops. i think the 2/4 will be low enough. plus i will still be puttin stuff in the back.... thanks everyone...
Old Dec 21, 2003 | 04:26 PM
  #29
Nick99Chevy's Avatar
AIM = ****
Old Dec 22, 2003 | 03:03 PM
  #30
Onyx
I am going to go with 2 in McGaughy's spindles up front
here is their site
http://www.mcgaughys.com/aboutus.htm
and the Hotchiss 4 in leafs out back....
My present to myself.....
AIM = Sucks - - - I agree 100%
