How to take top of dash off?
Old Mar 14, 2008 | 10:06 AM
10RamSport's Avatar
Formerly 08_gmc_slt-08/20/2010
Default How to take top of dash off?
Ok, I installed my AVIC D3 last weekend and I am needing to go back in and fix a misconnected wire. I really want to take the top of the dash off so I can get in there and tuck all those wires and harnesses away better. So how do I take the top off?
I know I pry the front bezel off and there are a bunch of screws along the trim...do I take all those out?
Thanks!
Old Mar 14, 2008 | 07:57 PM
sv650lex's Avatar
Once the front is off take out all the screws along the front. There are also 2 screws on each side behind the panel that snaps on. You will also need to pull out both vents on the passenger side. I think there is one screw behind each of those. To remove the grab bar stick, your hand in through the vent and push in on the white tabs (one on each side) and the grab bar should slide out. At that point the whole top of the dash should be able to slide back/off. If it doesn't come easy you missed one of the screws.
Old Mar 14, 2008 | 09:50 PM
10RamSport's Avatar
Sweet! Thanks!
Old Mar 15, 2008 | 05:34 AM
endo's Avatar
See the link in the sig, "factory nav info"....it has instructions for that.
Old Mar 15, 2008 | 09:16 AM
10RamSport's Avatar
Thats great! Thanks!
Blwn99x
Mar 24, 2023 11:14 AM
Pimpinpete
43
Dec 22, 2017 08:13 AM
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
Gadgetized
Oct 22, 2015 09:06 AM
someotherguy
Oct 5, 2015 12:49 PM
