How Do I Remove Amber 02 Gmc Headlight
Old Feb 25, 2004 | 06:13 PM
RUINED's Avatar
Default How Do I Remove Amber 02 Gmc Headlight
anyone have a pic of a successful removal of amber corner and advice on how you pulled it apart and rebonded them.........i know theres been articles but i missed them..............thanks
Old Feb 26, 2004 | 01:57 PM
Check with drkblusierra hes done this. Let me know how it turns out plan on doing this as soon as weather warms up.
Old Feb 26, 2004 | 03:31 PM
O3GMC's Avatar
12 Second Club
I went after mine with a large screwdriver...it wasnt the easiest thing I've ever done......it made the edge really rough but you can't see it from outside the truck. I sealed it back up with clear silicone.
I followed these instructions - http://mywebpages.comcast.net/00gmc/free_clear.htm
It has been a while but I think I used a blow dryer to soften up the factory sealant when prying it apart
Old Feb 26, 2004 | 08:18 PM
drkblusierra's Avatar
those instructions are a really vague description, but thats basically what i did....
What i used:
X-ACTO knife (have plenty of blades, they get dull)
3 Flat Head Screw Drivers (have regular size and longer one)
pliers
Muscle and paitence
*note* i suggest you have a friend around to help you hold the head lamp open while you get the reflector out. Also you may think your gonna crack or break them but they will hold up through some pretty good bending.
I first took the clips off and cut as much of the sealer as i could, then i used the screw drivers to pry the headlights open while i tried to cut more sealer. I finally had to break off part of the bottom lip to get to all the sealer so the head lamp would open enough to pull the reflector out. *This was the real hard part* I did this by myself and it was tough, but i had to pull the head lamp apart with my hands and then jam some object between the clear plastic and the gray backing plastic so that i could fish the reflector out with a screw driver. After i got them out i sealed them up with some clear silicone and put the clips back on and was done!
This pic shows the piece of the gray bottom lip that i broke off, and about how far i cut the sealer glue.... hope all this helps and makes sense!
This free mod really sucked to do and leaves you with sore fingers and hands and will probably take longer than 45 min to do.... but the look of clear headlights is well worth it.
Old Feb 26, 2004 | 08:38 PM
RUINED's Avatar
thanks for the feed back........sounds a bit brutal.......i would be willing to buy some that were done real clean............anyone know anyone?.........i live in az .........
Old Feb 26, 2004 | 08:56 PM
im living in AZ too, but don't know anyone whos willing to sell theres. I believe you can buy some aftermarket projector type for like $280 that come clear. http://www.sporttruckdirect.com/Head...sion_Kits.html here is a link to them
Old Feb 26, 2004 | 09:08 PM
RUINED's Avatar
yeah i saw those but when i called they were not available...........they have been saying that for awhile so i dont know........thought i would see about doing it myself........thanks
Old Feb 27, 2004 | 09:11 AM
Blake @ FMS's Avatar
FormerVendor
lol, i think my fingers are still hurting after doing that a year ago to a yukon. whatever you do, when your pulling out the amber piece, watch your finger placement, the lens will snap back on you like a slingshot. Worth the 2-3 hours i spent tho.
Old Feb 27, 2004 | 10:49 AM
For the Subaru Impreza, you can bake the lights for about 10-15 minutes @250 degrees. This softens the glue enough so that you can pull the light apart with a little leverage.
perhaps you can try this rather then using a blow dryer?
Old Feb 27, 2004 | 11:34 AM
Xsta Z 28's Avatar
I've heard of the "baking" trick. Works on Camaros, don't see why it wouldn't on a truck too.
