Hotchkis,anything I need to know?
Old May 10, 2004 | 05:51 PM
Default Hotchkis,anything I need to know?
I am going to install my hotchkis kit lowering kit tomorrow. Is there anything I need to know about the install that may not be in the instructions. I know with the belltech spindles I put on a few years ago I had to cut the tie rod ends to line it up. Do you have to with the coils. I think I will loosen the lower control arms and take the coil out the back.
Old May 10, 2004 | 08:15 PM
Up top
Old May 10, 2004 | 09:39 PM
Kano's Avatar
everything went well for me
actually its the best made kit ive ever seen
I made one mistake when i switched out the leafs
I tried to do it one at a time "dumass me"
I also drove mine about 200 miles then had it lined up
that made a huge difference
Hotchkis
OH yeah i also took my coils out the back and I made a compressor out of
an all thread rod so I wouldnt get my head taken off
Old May 10, 2004 | 10:42 PM
JSmith's Avatar
No problems with my install either. Everything you need parts wise comes with the kit and there is no fabricating involved.
Old May 10, 2004 | 10:45 PM
FILE's Avatar
Did you change your shocks too? How is your ride?
Old May 11, 2004 | 10:51 AM
JSmith's Avatar
Nope, still running the stock shocks. I plan on ordering some Edelbrocks very soon. The ride is ok with the stock shocks but it's pretty obvious when driving that they aren't up to the task of a stiffer lowered suspension.
Old May 11, 2004 | 03:41 PM
I got the front on today and it got to storming so I will finish the back up in the morning. I think I am really going to like this kit. The front was simple to put on. I don't think it sets as low as the belltech spindles I had on it before. Will have someone to post some pics for me when I get it done.
Old May 11, 2004 | 04:39 PM
JSmith's Avatar
Don't forget that over time the springs will sag and set in a little.
Old May 11, 2004 | 06:18 PM
Yeah I know. I am going to get a slam air kit for the back because I tow a couple of atv's and some things from time to time. How much did yours settle,I really don't want it to much because I didn't want a real low drop anyways. I just wanted to set it down a little and where it is right now is where I want it.
Old May 11, 2004 | 11:26 PM
JSmith's Avatar
I can't give you a measureable amount but they did sag a little but nothing drastic. It was more along the lines of one day noticing that the front sat a little lower than it used too.
