Help- Carriage works billet grille owners
Old Feb 23, 2005 | 05:57 PM
SnakeOiler's Avatar
Default Help- Carriage works billet grille owners
This applies to the cut-out and not the bolt over grille.
For the lower grille, the instructions state: "Center the top two tabs on the two molded flats of the grille shell. Drill 1/8" hole here being careful not to go through front cover."
I have a couple of issues with this: (1) there are no 'top two tabs' unless they are referring to the 'Z' brackets, in which case, I understand. (2) there are no molded flats on my grill shell - look at the pictures - what are they talking about?
I have no idea how to attach these Z brackets to the grill shell. Can anyone offer some advice/pictures, etc.?
Thanks
Attached Thumbnails Help- Carriage works billet grille owners-snap1.jpg   Help- Carriage works billet grille owners-snap2.jpg
Old Feb 23, 2005 | 07:15 PM
dragonman0325's Avatar
I had that one and sold it for the Trenz. I had the same problem you did. The Trenz is easy to install and looks better IMHO. Sorry I could'nt help.
Old Feb 23, 2005 | 07:54 PM
99Silver6.0's Avatar
You gotta get those plastic braces off there. U have to cut or grind away the melted sections that are layed in there. I know that is a little vague but thats the jist of it. I just screwed some small phillips screws covered in red loctite into the rear of the grille shell. Its been on my truck for nearly 2 years and it is still tight and looks good.
Old Feb 23, 2005 | 09:56 PM
SnakeOiler's Avatar
Hmmm . . so you have plastic and loctite holding that connection. I would feel better if I could use the clips that come with it.
Old Feb 23, 2005 | 10:12 PM
The location where that small bracket is located wouldnt allow it. I tried to make up some other bracket but I couldnt really come up with anything that would take the place of those small brackets.
6LITEREATER
Mar 4, 2026 06:13 AM
carid
Jul 24, 2015 05:00 AM
Ketis
Jul 23, 2015 12:37 PM
bgray
Jul 23, 2015 10:56 AM
