Hanger Install
Old Jun 15, 2004 | 12:39 PM
Default Hanger Install
Today I received my Eibach Rear hanger & shackle kit. I was reading the instructions and it said that it's recommended that you remove the bed. Do you guys have any tips on installing these? How did you install yours?
Old Jun 15, 2004 | 12:56 PM
FILE's Avatar
I have never done a hanger installl but i know for sure you don't have to remove the bed.
Old Jun 15, 2004 | 01:09 PM
It said to remove the bed and gas tank. The drill out the rivets and grind them smooth. Then bolt up the new hangers. Does this sound right?
Old Jun 15, 2004 | 01:25 PM
no need to remove the bed
Old Jun 15, 2004 | 01:28 PM
FILE's Avatar
The gas tank does have to dropped to remove the rivets.
Old Jun 15, 2004 | 10:19 PM
sleepersilverado's Avatar
you dont have to remove the bed but if you can it will make it a lot easier to drive the rivits out. when i lower something again with hangers i will remove the bed but i have a fiew things that will make it easier on me.
Old Jun 15, 2004 | 10:31 PM
Deckhand's Avatar
if you have the opportunity to take off the bed, it will make things alot easier.
I had to do it on the ground. Just take your time, and cuss alot... you'll eventually get through it.
Old Jun 15, 2004 | 10:43 PM
GREGGO's Avatar
Didn't have to move the gas tank or bed on the hangers. But that was due to a carefully placed torch used to get the rivets out. As for the shackles, on a step side, the back 4 bolts on the bed does have to be loosened to raise it up enough to get the bolts out.
Old Jun 16, 2004 | 10:20 AM
Right on
Plasma cutter
FlowmasterMufflers
Oct 26, 2015 06:19 PM
FlowmasterMufflers
Aug 14, 2015 01:04 PM
FlowmasterMufflers
Aug 14, 2015 12:47 PM
lxcoupe
Jul 21, 2015 02:12 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
