guys with painted door handles
Old Dec 5, 2006 | 05:14 PM
slownlow4.8's Avatar
Default guys with painted door handles
who has painted front passager door handle w/o key hole and how did you get it to work, because i just one and the pins do not line up and lock is way longer. someone please help!
Old Dec 5, 2006 | 08:03 PM
anyone?
Old Dec 6, 2006 | 01:39 AM
SSCrew_Cab's Avatar
Possible bad seller
I installed mine the exact same way as the others...you need to be absolutely sure that the pins are all in...
Old Dec 6, 2006 | 12:47 PM
SmokedSierra01's Avatar
Default Clarify
All of them should install the right way. It took about 30 minutes for me to put mine on. The hardest part is getting in the inside of the door. What you might need to do is pull hard on that metal rod that connects to the handle. I cut myself a few times trying to get in there. I dont really think you should have a problem with them fitting, where did you get the handles and what kind of truck (make/model) are you putting them on?
Old Dec 6, 2006 | 02:57 PM
magnetized's Avatar
I don't remember having any problems with mine, did your truck come from the factory without a pass. key hole?
Old Dec 6, 2006 | 04:46 PM
i used the rear door handle from a denali because i don't want the key hole,for a cleaner look but the 3 pins are in different places . i have a 03 gmc sierra RC and have seen guys w/o the passager key hole on RC.
Old Dec 6, 2006 | 05:18 PM
Yenkonoma's Avatar
i used escalade door handles, pass has no key hole, no probs on my install either. Maybe since it's a rear door handle something's diff.
Old Dec 6, 2006 | 05:20 PM
nightrunner's Avatar
Mr. Obvious
pas side no keyhole is for trucks with keyless entry
Old Dec 6, 2006 | 05:29 PM
i have keyless entry.
Old Dec 6, 2006 | 05:41 PM
Mr. Obvious
maybe its just on some of the newer ones then cause thats what chevy.com said a while back
BKnBLK05
Dec 28, 2015 08:52 PM
DwDrummer
Jul 24, 2015 07:05 AM
low2001gmc
Jul 21, 2015 02:09 PM
