Glue from stickers behind door
Old Sep 14, 2009 | 12:13 PM
whitegmc2003's Avatar
Default Glue from stickers behind door
their is still glue residue after i removed the SLE stickers from my cab. What would be the best way to take the residue off?
Old Sep 14, 2009 | 01:07 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
WD40.....it's the only thing I'd use it for
Old Sep 14, 2009 | 04:32 PM
budhayes3's Avatar
PT's Slowest Truck
I like 3M General Purpose Adhesive Remover, but it's a little pricey if you're only using it once lol. I've heard many times that WD-40 works great
Old Sep 14, 2009 | 04:40 PM
thanks guys
Old Sep 14, 2009 | 05:32 PM
URLIFEWASOC's Avatar
man we have some stuff here at my shop called Der Shiney stuff it works great on chrome but also is great for removing sticky residue. you just spray it on and let it sit for a bit then wipe the glue off. too bad they dont sell it any more in Cali any more you can probably find it online but WD40 will do the trick!
Old Sep 14, 2009 | 10:05 PM
fast84's Avatar
+1 for the MMM adhesive remover.
Old Sep 14, 2009 | 10:37 PM
hirdlej's Avatar
I use gasoline
Old Sep 15, 2009 | 02:07 AM
skolman91's Avatar
goo gone also works
Old Sep 15, 2009 | 03:03 AM
camochevy21's Avatar
Originally Posted by skolman91
goo gone also works
Goo gone works awesome but when I took mine off I used a heat gun and then after I got it cleaned up there was still a little residue left, so i hit it with goo gone, let it sit and then hit it with the heat gun and it wiped right off. I didn't use anything but a heat gun and goo gone to debage my whole truck. Clay bar doesn't hurt either once you're all said and done.
FlyingLow
Nov 24, 2015 10:05 AM
rumblebox
Oct 29, 2015 10:35 AM
BCraven1018
Oct 1, 2015 08:22 PM
Closer_2001
Sep 24, 2015 09:15 PM
RS/SS 4.8
Sep 17, 2015 09:17 PM
