Gauge Lighting Instructions
Old Apr 14, 2005 | 02:41 PM
  #61
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Im fixing to go outside right now and look at it.
Old Apr 14, 2005 | 03:14 PM
  #62
1slow01Z71's Avatar
Ok just pulled the ac cluster it can be done you have to take the ***** off 6 screws out of the white panel and there are some wierd little lights in there but it can be done I dont have alot of time to investigate right now but when I get home Ill take a closer look but it can be done ill keep yall posted.
Old Apr 14, 2005 | 06:47 PM
  #63
1slow01Z71's Avatar
Well upon closer inspection i looked at the bulbs and it looks like in order to change out the bulb you will have to heat up the two prongs on the bulb with a solder gun to get it out and that is going to be a huge PITA. Im going to try and see if the bulb will come out but it looks like it will have to be soldered.
Old Apr 14, 2005 | 07:30 PM
  #64
SIN's Avatar
SIN
I'm fairly decent at soldering. I just dont have the an extra control from a Tahoe/Suburban in case I screw up. That's why I said you could practice on the one I have. I have the blue T1.5/74 bulbs too. I ordered some just in case....I can do the soldering but I wouldn't have anything to test it in.
Old Apr 14, 2005 | 08:43 PM
  #65
1slow01Z71's Avatar
Well maybe we can meet up i dont know what kind of bulbs they are but if you can soldier in the led bulbs then great. Taking it out and apart isnt a problem. Are they bulbs that you are talking about the ones that go in there.
Old Apr 14, 2005 | 08:58 PM
  #66
SSlow 4.8's Avatar
any if anyone screws up too badly.. pm me, i have the oem ones still soddered to their original twist locks
Old Apr 14, 2005 | 10:05 PM
  #67
1slow01Z71's Avatar
Im talking about the bulbs for the ac controls that backlight it. I have looked closer and played with it and you definately have to solder new bulbs in. I doubt I will mess with it unless I just get really bored cause if I do the ac ill end up doing the 4wd buttons cargo lamp fog lights and dimmer and light switch and thats alot of soldering not to mess up at all and IMO not really worth it at the moment. Tmorrow I will look at the other switches and see if they are as difficult if they are easy then ill think about doing everything.
Old Apr 14, 2005 | 10:07 PM
  #68
SIN's Avatar
SIN
OK...I'll solder the ones I have and I'll meet up with you to plug it in for a test..
Old Apr 14, 2005 | 10:34 PM
  #69
1slow01Z71's Avatar
pm me when you get it done
Old Apr 15, 2005 | 12:48 AM
  #70
Faze2183's Avatar
someones gunna get lucky
