foggin ass window????
Old Aug 21, 2006 | 10:56 AM
BLACKND's Avatar
Default foggin *** window????
I got to find something to clear up my front windshield. I love to drive with the windows open, all the time although with the heat lately, I haven't been doing it in the afternoons. So I look forward to my morning commute with the windows open. But the damn front windshield fogs up like crazy. This is on the inside that it fogs up, but it stays real streaky, and yes I can wipe it off, but its hard to reach across the truck to the passenger side to wipe while driving, and it just comes right back. Is there anything I can use to help prevent the damn fog and nastiness on the inside of my window?
Old Aug 21, 2006 | 11:02 AM
nonnieselman's Avatar
I hear ya man, mine does the same thing. We got to find out how to fix this!! Its annoying!!!!
Old Aug 21, 2006 | 11:12 AM
COLDZ71's Avatar
Rain X makes some antifog for the inside of windows. You could look for some of that. I dont know if they still make it though. Also you can run your ac with whatever temperature you want. I heard that the ac will dry the air that is coming out of your vents.
Old Aug 21, 2006 | 11:47 AM
TG02Z71's Avatar
Make sure you have your vents set to bring in air to cool it not just reciculate the air that's in the cab. That should help some.
My wife used to do this **** all the time in the winter which makes it fog up in about 10 seconds.
Old Aug 21, 2006 | 12:29 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
turn the defroster on thats the only thing I have found that will keep it fomr doing that
Old Aug 21, 2006 | 01:05 PM
BLACKND's Avatar
Yeah, well it will go away with the defroster on, it just seems stupid to drive with the windows open and the defroster on. I'll see if I can't do some looking and find some anti-fog stuff, just for testing at least.
Old Aug 21, 2006 | 01:50 PM
00MysticZ/05Crew's Avatar
if you have or use Zanio try a little bit of Z6 that may work i may try this tonight also
Old Aug 21, 2006 | 02:39 PM
kbracing96's Avatar
The reason it doesn’t fog with the defroster on, is it runs the AC, which cools the air, causing the moisture in the air to condensate out of it and then it heats the air back up though the heater core and blows the dry, warm air on to the glass. You get the same affect with just the AC turned on and put the temp **** on what ever temp you want.
Old Aug 21, 2006 | 04:09 PM
JT-bo's Avatar
when i used to wear eyeglasses i would have trouble with them fogging up so i found some antifog spray at walmart. this was about 6 years ago so i'm not sure if its not around anymore but it worked. it might work on windows
Old Aug 21, 2006 | 09:44 PM
.T.'s Avatar
.T.
Glad to hear it's not just mine doing that
