fixing nicks in alluminum wheels
Old Feb 9, 2006 | 08:22 PM
TURBHOE's Avatar
Default fixing nicks in alluminum wheels
i got some used wheels today they look great but they have these little tiny nicks in a circular patterm about 2" from the edge of the wheel the pattern is about an 1" wide or so and goes all the way arounbd the wheel and its on all 4 how can i get these out i was thinking som 500 to 1000 grit sand paper to get them down the move to 1500 then to 2000 then polish will this work or no?
Old Feb 9, 2006 | 08:26 PM
TarheelZ's Avatar
What you're thinking will work about right, but just be careful to use light/smooth strokes with the grittier (less-fine) paper. If you have or can get a Dremel with a polishing kit, THAT's the ticket! Good luck!
Old Feb 9, 2006 | 08:43 PM
TURBHOE's Avatar
where can i get one of these polishing kits i have a die grinder a roto zip and a dremel so which ever works.
Old Feb 10, 2006 | 08:06 PM
TarheelZ's Avatar
Lowe's and Home Depot carry the Dremel polishing kits in the tools section. Anyplace that sells the Dremel tool should also have different kits for grinding, polishing, or whatever. They usually run about $11 or so and have several different wheels and tips.
Old Feb 10, 2006 | 08:17 PM
TURBHOE's Avatar
i found one today but man it looks like i would need like 4 of these thing there were tiny bits in them.
jdb11386
Dec 3, 2015 09:34 PM
Lamartian92
Sep 10, 2015 09:27 PM
hartinclay
Aug 2, 2015 06:44 PM
Ketis
Jul 23, 2015 12:37 PM
