ebay fog lights
Old Oct 25, 2004 | 01:48 PM
dkubricht's Avatar
Question ebay fog lights
does this look like everything I need to install foglights?
ebay
another one
Thanks
Old Oct 25, 2004 | 03:31 PM
02BlueStepside's Avatar
Everything that I got in my kit when I ordered. I had to get my pcm flashed so it would "read" that I had foglights though. I paid $83 and some change through GM Parts Direct. For the pcm they charged $80!
Old Oct 25, 2004 | 07:12 PM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
I saw some of the same auctions on ebay, and I had seriously considered bidding. That was until I saw that you'd have to have your computer flashed.
Old Oct 25, 2004 | 07:36 PM
SnakeOiler's Avatar
ebay
another one
Thanks
The first is definitely the best bet. I wouldn't pay over $80 for it. And like they say, the pcm has to be programmed to react to this. I believe if you access to a Tech II, then you should be able to do this.
When I had my 2000 SCSB, I bought this kit and I happen to be a good parts dept. customer, so I had them see if one of the service guys would set my pcm. He did it in the parking lot, no charge.
Old Oct 25, 2004 | 07:47 PM
I need to make some friends.
Old Oct 25, 2004 | 08:21 PM
chevymec's Avatar
What is so crazy about the kit is that if you by a single fog light, its like $60+. Had to buy one a while back and then saw that you could by the kit. but never again!!
Old Oct 25, 2004 | 08:46 PM
agreif's Avatar
Just buy a similar set of aftermarkets that look the same size. You get the look, plus you get more wattage and light without those damn factory housings melting under more than 27W.
http://www.jcwhitney.com/autoparts/P...p-5302/c-10101
http://www.jcwhitney.com/autoparts/P...p-6469/c-10101
Andrew
Old Oct 25, 2004 | 10:54 PM
Poltergeist's Avatar
Is it the PCM or the BCM that needs to be reprogrammed??
Old Oct 25, 2004 | 11:37 PM
blk03's Avatar
I am going to eventually get some for mine off of ebay. From what I have heard, the 03s (and most earlier models) don't need any pcm programming.
Old Oct 26, 2004 | 03:27 PM
Yea, its the BCM that needs programmed, not the PCM.
