drop kit question
Old Oct 6, 2003 | 01:59 PM
02chevyracing's Avatar
14 Second Truck Club
Default drop kit question
what kind of drop does everyone have? what is the best drop? I dont want my truck to bounce around,so i was think about getting the belltech 2" front spindles and the rear 4" blocks with hangers. would their be a better set up?
should i use the belltech 1" front springs or my stock springs? i just want a nice looking drop with a smooth ride.
Old Oct 6, 2003 | 03:48 PM
CHAGO's Avatar
Default Re: drop kit question
i have a rigged up drop kit:
front - 2" belltech drop springs
back - 2" belltech shackes and chassis tech hangars
using stock front & back shocks; i have a lil bounciness on the rear now that i put the 17" denali rims and the big michelin tires, but i'm very impressed with the ride on it with the factory shocks.
Old Oct 6, 2003 | 04:35 PM
JSmith's Avatar
Once again, Hotchkis.
By the way, why "" icon? You don't seem mad in your post.
Old Oct 6, 2003 | 04:36 PM
GREGGO's Avatar
All depends on how much you want to spend. The cheapest way is spring, shackles and hangers. Mine is a 3/4 drop done that way, and I have no problem with the ride quality.
Old Oct 6, 2003 | 04:55 PM
abbo7's Avatar
Someone was saying that when you tow (a boat, trailor, nothing too big.) with the hotchkis 4/2 it will sag in the rear over time. Is this true? I mean I really like the idea of the hotchkis suspension syetem but would not want it to sag over time.
Old Oct 6, 2003 | 07:55 PM
sleepersilverado's Avatar
do you mean shackles and hangers? blocks will raise it unless yours is fwd. i have control arms in the front and springs out back. a little rough because stock still rides cushy and back is chollie due to the springs being stiffer. it is a 4-4 drop.
Old Oct 6, 2003 | 08:18 PM
GREGGO's Avatar
I have heard this to with the Hotchkis kit. That why I use airshocks out back with my shackle / hanger setup.
Old Oct 6, 2003 | 11:21 PM
JSmith's Avatar
I've towed only a handful of times since the Hotchkis was installed. I don't have the sag you describe but I also didn't do alot of towing either.
Old Oct 6, 2003 | 11:50 PM
Deckhand's Avatar
i cant beleive you guys dont bottom out, i use to with the belltech rear hanger/shackle... so i used the factory shackle. but i am still using the belltech hanger
it gives my truck about a 1 1/4" rake
Old Oct 7, 2003 | 06:32 AM
leochevy2001's Avatar
Deckhand - could the bottoming out problem be from the type of shocks you are using?
