DRLS and Turn Signals
Old Dec 21, 2003 | 11:54 AM
02 Tahoe on 20s's Avatar
Default DRLS and Turn Signals
Hi. Is there a way to get the DRLs and the Turn Signals to be the same brightness? The turn signals are always dimmer, and i figured someone might know how to do it. Is it a fuse to pull? Thanks
Ben
Old Dec 21, 2003 | 12:32 PM
99Silver6.0's Avatar
You can flip the + wires around on the turn signal sockets. That way the Park lamp will be the brighter filament. And the turn signal will be on the smaller dimmer filament. Should be pretty easy to do. I can try to check wiring colors on my truck. But it can be done that way.
Old Dec 21, 2003 | 01:33 PM
yeah, if you could, that would help alot. Thanks man
Ben
Old Dec 21, 2003 | 02:44 PM
are you talking about the blinker or the running light??
If you want your running lights as bright as the daytime ones, and reverse the wires like he is saying, you will get the rice rocket fast blinker thing going, and your blinker will not be visible at night, well it will be barely visible
Old Dec 21, 2003 | 03:08 PM
ok. So, what else can i do to make those lights the same intensity? Oh, and by the way, im talking about the bulbs directly next to the DRLs. The other set of 3157 bulbs.
dsbodley
Nov 14, 2015 09:46 PM
smok'nZ
Oct 6, 2015 01:14 PM
turbo6c3
Oct 5, 2015 06:11 PM
Chevy305
Sep 28, 2015 09:21 PM
trevorh1
Sep 27, 2015 08:47 PM
