DRLS and Turn Signals
Hi. Is there a way to get the DRLs and the Turn Signals to be the same brightness? The turn signals are always dimmer, and i figured someone might know how to do it. Is it a fuse to pull? Thanks
Ben
Ben
You can flip the + wires around on the turn signal sockets. That way the Park lamp will be the brighter filament. And the turn signal will be on the smaller dimmer filament. Should be pretty easy to do. I can try to check wiring colors on my truck. But it can be done that way.
are you talking about the blinker or the running light??
If you want your running lights as bright as the daytime ones, and reverse the wires like he is saying, you will get the rice rocket fast blinker thing going, and your blinker will not be visible at night, well it will be barely visible
