Don't bite my head off please..
Old Jun 9, 2005 | 06:49 PM
Coban's Avatar
Default Don't bite my head off please..
Hey guys, its about wheel rub. I'm looking at 20X8.5 wheels, +14mm offset. What size tire can I run (the biggest) without any rub at all? I like a little more meat on my wheels. Stock ride height and maybe a 2" drop in the back later.
Old Jun 9, 2005 | 10:19 PM
SnakeOiler's Avatar
by biggest, I assume you mean widest.
You should be able to get a 285 on there without a problem. But I would get a wheel with a little more offset, like around +30 to +32 (6" backspace)
Old Jun 10, 2005 | 12:11 AM
Coban's Avatar
I'd also like to run a 45 or 50 series tire. What would make the wheels flush with the fenders?
Old Jun 10, 2005 | 12:12 AM
Coban's Avatar
I meant what offset would make them flush..
Old Jun 10, 2005 | 05:59 AM
SnakeOiler's Avatar
The above would get you there. But a 285/50 would be a little more than an inch over stock height.
So, you might want to just go with a 275/45 in order to maintain something close to stock height. In which case, you might get away with using your mentioned +14mm offset wheel.
I personally would go with a 6" backspace, but I do know many people on the board here are running a 8.5" wide with 5.3 - 5.5" backspace (your +14mm would be a 5.3" backspace).
Old Jun 10, 2005 | 06:42 AM
Juiced2000SS's Avatar
I have 20x8.5 with a 275/55/20 6" BS. Goodyear Eagle LS same as factory puts on and they rub on the front at full turning. Sit flush with fenders. 04 Silv. ECSB
Old Jun 10, 2005 | 06:51 AM
smooth sierra's Avatar
275/55 is what I have and they definitely fill up the fenders. I have the 2" shackles on the rear also. mine will slightly rub on the front if I turn all the way and hit a bump. during normal driving they don't.
this is the same size tire that the joe gibbs and SS silverados come with. they are some 'meaty' tires.
Old Jun 10, 2005 | 07:30 AM
StrokerAce03's Avatar
I'm running a 8-inch wide wheel with 5 inches of backspace and they sit flush. I also got 285/50/20 tires with a 2.5 rear drop and they don't rub at all; there's plenty of clearance.
Old Jun 10, 2005 | 11:58 AM
IntroWheels's Avatar
With only a 2" drop in the rear, a 5.5" backspace would be about perfect with like a 275/55/20. That is the stock tire from a Silverado SS, so you can get them pretty cheap.
Old Jun 10, 2005 | 06:25 PM
Coban's Avatar
Sweet, these are exactly the things I wanted to know
Oobray
Jun 13, 2022 03:38 AM
Greatdivider
Sep 9, 2015 09:52 AM
lsxperformance
Aug 2, 2015 10:08 AM
lxcoupe
Jul 30, 2015 02:42 PM
rudvirus
Jul 15, 2015 09:31 AM
