Denali front cap ??
Old Oct 24, 2004 | 10:56 AM
bodyguard6799's Avatar
Default Denali front cap ??
Ok, I'm in the process of finishing my Denali front cap conversion, I have the insert, bumber cover, grill, and waiting on my lights. But I'm wondering about those black plastic filler peices that attatch to the light brackets directly under the lights. Are the ones for the Seirra and the Denali the same and is there another plastic filler that goes across the whole front in the center?? Because I dont think you should be able to see the radiator support if you look in the gap b/w the grill and bumper cover. And I dont have a huge gap b/w threm either, it could be a little closer but I'm working on that. THANKS!!
Old Oct 24, 2004 | 11:27 AM
one03sierra's Avatar
Formerly one92rs
Talking
i think they might be different since the turn siganls are different. i had to put in spacers on my bumper mounting to get the gap smaller.
Old Oct 24, 2004 | 02:13 PM
I think they are different too. What kind of spacers and where exactly did you put them?? I was thinking of having my body man cu the bumber mounting brackets off from the front part of the frame and welding them up higher to close the gap because I dont want to put the bumper insert in a bind since its fiberglass reinforced plastic??
Old Oct 24, 2004 | 04:26 PM
Formerly one92rs
Talking
i put them on top where the bumper mounts to the frame and the bolt goes thru.
Old Oct 24, 2004 | 09:46 PM
Did you knock the bottom mounting tabs up higher?? Because it just seems like you are strecthing the insert (putting it a bind). Atleast it seems that way to me. I think I'm gonna try chopping the brackets and re weld them. Thanks for the info. Also, I was thinking about making a plastic filler to put in the center so you cant see the radiator support through the gap- I have an extra tailgate cat thats kind of beat up I'll use that. Thanks again!!
Old Oct 24, 2004 | 10:27 PM
Formerly one92rs
Talking
yes i did. sorry about that.
Old Oct 24, 2004 | 10:41 PM
How much of a gap do you have on the ends?? Is the bumpercover touching the grill?? Right now the cover is close to 2 inches from the bottom of the grill. I was wanting to move up atleast another inch. Thanks
Old Oct 25, 2004 | 06:13 AM
Formerly one92rs
Talking
after i spaced it out it would almost touch on the ends by the fender well and was about 3/4 of an inch acroos the front. i would take some pics but i have the front end off right now doing some repairs.
Gmc_sierra
Aug 21, 2015 10:08 AM
BigEd_72455
Aug 8, 2015 04:49 PM
08nali
Jul 23, 2015 11:39 PM
Ketis
Jul 23, 2015 12:37 PM
Ammadien
Jul 22, 2015 08:50 PM
