Decladding leftovers
Old Feb 4, 2015 | 02:03 PM
RedRegency's Avatar
Originally Posted by GM_Devil
how did you finish stripping the glue off? im in the process of decladding an have a little bit of glue in between the machine marks that i cant get off.
GM_D, the glue can be very difficult to get off if you want the machine marks left on the surface.
I used Aircraft Stripper in an aerosol can and a power washer. I found that the best result were when:
1. the aerosol was kept warm. I wore a hoodie and kept the can in the front pocket when I wasn't using it. Probably wont be as important to do that if you're doing this in the summer. The temperature of the can made a large difference on how effective it was on the glue.
2. I used a high psi tip for a pressure washer. Those dinky local car washes and electric pressure washers probably wont do it. I used a tip I had on hand Briggs & Stratton Quick Connect Turbo Nozzle for Pressure Washers - Lawn & Garden - Pressure Washers - Pressure Washer Accessories. Worked well. A concrete tip on a lower psi may have worked quicker but aluminum is a soft metal.
Patience and about 6 cans of stripper is what got mine done. Results may vary
Old Feb 4, 2015 | 03:48 PM
GM_Devil's Avatar
i tried the aircraft stripper in a can but i didnt know the temp made any difference. i caved an took the wheels to get a chemical soak yesterday, guy said hed only charge me 50 bucks for all 4 wheels. so well see if that works.
TrendSetter
Nov 26, 2018 07:18 AM
dballs2g5
Nov 4, 2015 11:47 AM
wretched73
Oct 28, 2015 09:21 PM
lxcoupe
Aug 31, 2015 06:27 PM
