DDM HID bulbs sit loose in the housings
Old 01-27-2012, 05:33 PM
Ferocity02's Avatar
Default DDM HID bulbs sit loose in the housings
I picked up two pairs of DDM HID's for my low and high beams and noticed that the bulbs sit very loose in the housings. I have tried them in both my stock and **** eBay housings. I compared them to the stock bulbs and the base of the HID bulbs is physically thinner, so the ring piece that holds them in place doesn't press down enough, if that makes sense.
This is an issue because if I move the bulb in the housing it greatly affects the beam. At 25' from a wall, I can move the beam up and down about 2' just by moving the bulb in the housing.
Anyone have this issue with DDM HID bulbs or other brands? I'm looking for a simple fix if possible. Might have to hit up the hardware store and see if I can make a spacer or something.
Old 01-28-2012, 11:12 AM
5speedsilverado's Avatar
that seems odd, my bulbs from them were a really snug fit, had to use pliers to twist them in
Old 01-28-2012, 11:31 AM
SloStepSide's Avatar
I had to use a o ring on mine. No biggie works just as good.
Old 01-28-2012, 04:48 PM
Ferocity02's Avatar
The eBay headlights I'm using use 3 screws to hold the bulb in place. I bought some longer screws and neoprene backed washers for them. The neoprene helps push down on the backside of the bulb to hold it securely in place. Seems like it will work for now. I only did the low-beams because I broke a high-beam HID bulb while rushing
Old 01-29-2012, 12:01 PM
YenkoST's Avatar
Agreed...I've installed multiple sets...all were very snug fitting.
Old 01-29-2012, 12:05 PM
La SS's Avatar
Had to twist mine on with pliers lol
Old 01-29-2012, 02:35 PM
Ferocity02's Avatar
What the heck. I've had three pairs of 9005/9006 HID bulbs from DDM and they were loose as hell in the housings
madmann26
04-29-2020 09:17 AM
lukn4trbl355
10-21-2015 11:19 PM
smok'nZ
10-06-2015 01:14 PM
carid
10-01-2015 09:22 AM
the owl
09-04-2015 04:09 PM
Quick Reply: DDM HID bulbs sit loose in the housings
