dash gauge question:looking for 120 speedo
Old Sep 28, 2004 | 03:26 PM
Default dash gauge question:looking for 120 speedo
hey guys, im looking to change my dash to the 120 speedo. where do you get it from, do you have to do any programming to make it read right or is it simple plug and play. i will be doing programming to remove top speed limiter. 98 miles an hour is just not an impressive top speed. my base v6 camaro saw 113 at least. any help is appreciated.
also, is there a speedo that goes higher than the 120. if so i'll get that instead
Old Sep 28, 2004 | 05:52 PM
Nick99Chevy's Avatar
Do you have programmer or custom tune to remove the governor? An Escalade or Denali cluster is a direct swap and they both go to 120.
Old Sep 28, 2004 | 06:07 PM
well i was told that for 500 i could get an ls1 edit tune at jg motorsports and programmers usually run around 400 so i just figured id get the whole thing tuned and what not
Old Sep 28, 2004 | 06:15 PM
SilverSSGabe's Avatar
Buy an Silver 05 SS truck. Than you will have one.
Old Sep 28, 2004 | 06:27 PM
wow silverss, are you saying that youd donate me the money to do that, what a friend. btw, interesting little link ya got there
Old Sep 28, 2004 | 06:37 PM
Check those out the first one are from Denali suv's.
The second one are Caddy Escalade clusters, I think from 99 to 02 can be swapped. The 03 are a diff design, hope this help. Laters, The Bandit-Z.
http://motors.search.ebay.com/DENALI...ertyZ2QQsotrZ2
http://motors.search.ebay.com/ESCALA...trypageZsearch
Old Sep 28, 2004 | 06:43 PM
thanks bandit...some people are kinda proud of theirs. you dont happen to have a link about how to hook up the tranny gauge do you? thanks for the help
Old Sep 28, 2004 | 06:51 PM
Well if you buy either (Denali/Escalade) guage cluster it would be a direct swap. Our trucks allready have the trans temp sensor in them, you just need to change clusters that have trans temp guage(Denali/Escalade). If you buy a new guage cluster your odometer will start from 0 miles unless you take it to the dealership to have it programmed. If you buy a used be sure of how many miles it has? Laters
Old Sep 28, 2004 | 07:31 PM
Just giving you a hard time.
