Color sanding
Old Feb 12, 2009 | 02:09 PM
fatdog41's Avatar
Default Color sanding
I am painting a set of mirror caps for my NNBS. I used GM aerosol paint so I knew it would match correctly. The finish is dull, not even close to the rest of the truck and the label says you can rub out with a mild polishing compound after 48 hours. It says NOTHING about applying a clear coat.
Should I:
  1. Rub out, polish and wax and forget it?
  2. Color sand, rub out, polish, wax?
  3. Color sand, rub out, CLEARCOAT, color sand, rub out, polish, wax?
  4. CLEARCOAT, color sand, rub out, polish, wax?
  5. Other
Like I said, the color matches but is dull. I have some Duplicolor clear but it is not that shiny.
Old Feb 12, 2009 | 08:24 PM
coldkillinTA's Avatar
4. But make sure the surface is perfectly clean. Go over them with IP alcohol or similar bbefore clear
Old Feb 13, 2009 | 01:31 AM
95 bright teal's Avatar
#4 gm is basecoat clearcoat, finish wont look right without the clear
cheyenne383
Nov 13, 2015 09:24 AM
Superman09
Sep 25, 2015 05:55 AM
RONIN LSX
Sep 19, 2015 05:33 PM
DrX
Sep 18, 2015 08:53 AM
