Calling C3 people and others in the know...........
Old Feb 13, 2017 | 01:27 PM
Mark Johnson's Avatar
All I can find is tan color- which is cool, too. Just have to get the code to paint some pieces. Add some elegance to the ride...........
Even found an outlet that sells headliner fabric. Though I wonder if I'll hafta trim it myself....
Old Feb 14, 2017 | 11:02 AM
One more thing, guys. Should I also replace the seat foam while down there.............
Old Feb 26, 2017 | 03:14 PM
Hey guys, thanks for all the inputs. I've decided to go the paint route; cheaper and faster than replacing panels and so fourth. One more question, anyone know of a fabric paint? THinkin' if I could salvage the headliner with the adhesive and make it the right color.......
TIA
Old Feb 26, 2017 | 03:21 PM
03sierraslt's Avatar
Mine has the tan interior also.
Old Feb 26, 2017 | 03:49 PM
Tan- nice, mine has that 'neutral' grey. Was looking at tan B4 I found this out......
Old Feb 26, 2017 | 05:55 PM
MrHorsepowerLSx's Avatar
11 Second Club
As mentioned by others the headliner is cake to remove, you could recover it your self if you have the time. As for the interior swap, the 99-02 steering wheel will also be different as the steering wheel controls will no longer useful that came on your truck. As for the door panels, they will fit but the 03+ panels fasten to the doors bit differently using large push fastener in front of the panel, and a screw in the back of the panel ( back being closest to the door jamb ) also the master switch on the drivers side door and pass. Door use a different door harness/connector and will not work. You would have to install the door panel and use your trucks window switches..... they also fasten a bit differently then the 99-02 ( which uses tension springs ) 03+ is fastened to the door panel with screws from " the inside "
Which means that the window switches stay with door panel and need to be removed after the panel is off the door
Old Feb 26, 2017 | 06:13 PM
Thanks for the information on the panel differences, which is why I'm opting for the paint route. On the steering wheel subject, can I swap may airbag guts over to this wheel.........
Old Feb 26, 2017 | 07:08 PM
11 Second Club
Yes you should be able too
Old Feb 27, 2017 | 07:10 PM
One more question for y'all, wan I incorporate/ retrofit an A pillar grab handle while I'm in there changing colors.................
Old Mar 3, 2017 | 10:20 AM
One more question- the bottom heating portion of the seat isn't heating, my boys are cold. So when I'm replacing the bottom cover I'd also like to replace that lower heating element; any pointers, part numbers- where to get this.............
TIA
