Broken arm rest question on rear buckets in Sub
Old Sep 28, 2004 | 08:17 AM
BigBores's Avatar
Default Broken arm rest question on rear buckets in Sub
One of the arm rests on the rear (2nd row) buckets appears to be broken. It droops about 2 inches lower than level when in the down position. The dealer has the truck right now to replace the rear AC evaporator and I asked them to look at the rear arm rest. They said $480 to fix it. Does this sound right?
I think someone at Chevy needs to lay off the crack.
Old Sep 28, 2004 | 12:00 PM
TWANKYDEUCE's Avatar
lay off the crack is right. $480 just to replace the armrest? Fid out exactly whats wrong with it and see if you can replace it by getting parts from a cheaper place
Old Sep 29, 2004 | 01:20 AM
B3Enterprise's Avatar
i would see if your arm rest button is stuck. there is a small pin hole on the bottom of the arm rest near the pivot point of the arm. if that buttom is stuck your arm rest will drop till it touched the seat. Hope that helps.
DarkhorSe_SS
Aug 20, 2015 08:58 AM
Shtbox
Aug 2, 2015 10:52 PM
USMCvet0311
Aug 1, 2015 07:45 AM
maxspeed05V
Jul 19, 2015 07:08 PM
