Anyone removed wiper arms/cowl???
Old Jan 14, 2007 | 12:38 PM
agreif's Avatar
Default Anyone removed wiper arms/cowl???
I got the bolt off, but hell if I can get the "rock back and forth method" to work on getting the wiper arms off. Trying to get the wiper cowl off and need to get those off first. Any suggestions would be appreciated.
Old Jan 14, 2007 | 12:41 PM
'89ChevyMadneSS's Avatar
plasma cutter should make short work of em...
lol i dont know havent messed with any of the newer style, u sure thres not a clip or anything your missing??
Old Jan 14, 2007 | 01:01 PM
truckmann's Avatar
Here is what the service manual says for an 03 model.
1.Mark the position of the wiper blade on the windshield with a suitable
2.marker or a piece of masking tape.
3.Disconnect the washer hose.
4.Remove the cover from the nut on the wiper arm.
5.Remove the nut from the wiper arm.
6.Remove the wiper arm from the drive shaft. IMPORTANT: Use a battery terminal puller to remove the wiper arm from the drive shaft.
7.Clean the knurls of the drive shaft with a wire brush.
Old Jan 14, 2007 | 01:38 PM
agreif's Avatar
See that puller factor is what I don't have. THe haynes says to rock it back and forth, looks like I'll be putting it back together defeated.
Old Jan 15, 2007 | 12:04 PM
High Pressure's Avatar
where the wipper arm bends, Press down toward the windshield then pull the arm up off the post It will work
Old Jan 15, 2007 | 08:42 PM
02BlueStepside's Avatar
I remember I had to play with mine to get them off. I think I pulled the wiper up, where it bends, off the windshield and it made it easier to get off the stud.
Old Jan 15, 2007 | 10:42 PM
agreif's Avatar
ok, I'll try that before going to get the battery puller deal. Thanks guys.
dsbodley
Nov 14, 2015 09:46 PM
cheyenne383
Nov 13, 2015 09:24 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
69z-28
Sep 21, 2015 07:31 AM
