Anybody running Boss 330 Wheels?
Old Mar 31, 2009 | 10:43 PM
thanks
Old Apr 1, 2009 | 08:24 AM
skyhighsami's Avatar
no title here
With that 30mm offset you might need a small spacer like something around a 1/4 inch or so on the rear wheels. Mine on wife's truck when I lowered it the rearend shifted slightly and one wheel rubbed on the inner fenders when turning and the axle articulated. So a 1/4 inch spacer and the problem was solved.
Old Apr 1, 2009 | 08:37 AM
no title here
Also, on the Yukon it has a multilink and coil spring suspension so with your's being leaf springs I wouldn't expect you to have the same problems I did, I was just sharing my issues with running what I recommended
Old Apr 1, 2009 | 12:28 PM
3DTIM's Avatar
Originally Posted by RandomHero
Either the 14mm offset or 30mm(I believe it is) offset will work. However, if you ever plan on lowering your truck, the 30mm offset is MUCH MUCH more desirable. The 14mm offset will work just fine, but not on anything much lower than a 2/4 drop unless you run a much smaller than normal size tire.
EDIT-The general rule of thumb is that you want less than a 3" difference between the width of the wheel and the backspacing of the rim. For instance a 14mm offset on a 20x8.5 rim equates to 5.25 backspacing which is a 3.25" difference between the width/backspacing and certainly isn't optimal.
If I drop it any it will be no more than 2/4 drop. I like the Boss and the enkei rt6 wheels. But from what I read the enkei rt6 wheels will not work. I like a flat spoke but finding one like the enkei wheel is hard to do will I have found nun.
Old Apr 1, 2009 | 12:37 PM
07redchevy's Avatar
i used to have them in 24s
Old Apr 1, 2009 | 01:35 PM
Stepside04's Avatar
Nice truck, that thing is sick as hell!
Old Apr 1, 2009 | 07:49 PM
3DTIM's Avatar
What size are those? Looks like I will go with 20's. One thing I do not like about the newer wheels is you can not get them in different width's. Like a 20x10 all I see is 20x8.5. I am from the old school you when you could get 15x8 15x10
Old Apr 1, 2009 | 09:20 PM
no title here
Those look to be a 24x10 with a 275/35 or something like that. I had 275/30/24s on my truck and I wouldn't really recommend running a tire that small on a DD. It made me a nervous wreck when I would drive it on the interstate or anywhere that I didn't know the roads
Old Apr 1, 2009 | 09:27 PM
3DTIM's Avatar
I was thinking the something. And I will be pulling a trailer some.
stealthperf
34
Feb 14, 2016 11:35 AM
madmann26
Jul 24, 2015 10:35 PM
GMCtrk
Jul 17, 2015 06:39 PM
fcompean
Jul 15, 2015 09:55 PM
