Above Console Attaching Question
Old Sep 27, 2005 | 07:49 AM
JayBirdWs6's Avatar
Default Above Console Attaching Question
How hard is it or would it be to attach an above console to the roof between the sun visior's?
Old Sep 27, 2005 | 02:40 PM
Fogle07's Avatar
you want to put a factory one where there isnt one now? if so im pretty sure it should have the mounting stuff already up there youll just have to cut out a hole for the console.
Old Sep 27, 2005 | 03:08 PM
JayBirdWs6's Avatar
Correct. I got one off ebay coming in today OEM silverado center console just the 2 maps lights and pocket.
Old Sep 27, 2005 | 03:13 PM
Fogle07's Avatar
alright now try to pull your headliner down a little and there should be a little place where you can put a screw in. you put the console up there then slide it back a little and it will kinda lock in place then you put a screw in it up close to the glass. hope this helps some
Old Sep 27, 2005 | 05:35 PM
JayBirdWs6's Avatar
I pulled the headliner alittle and found a rounded out peice of foam that is outlining it feels like an oval hole in the metal. Thats my biggest question. How to get to the holes if there are any and to plug this thing up and see if it works. What if i pull the headliner alittle more how hard would it be to re-glue it back up so that its alittle easier to see what i am poking at.
Old Sep 28, 2005 | 06:26 AM
Fogle07's Avatar
take off your a-pillars and your rear pillars, take out your light up top and the headliner should come right out
Old Sep 28, 2005 | 06:53 AM
JayBirdWs6's Avatar
This sounds like a weekend event for me..lol I will have to try it this weekend. I dont get home from work til 6:30..Thanks again for your help fogle
Old Oct 15, 2005 | 05:10 PM
JayBirdWs6's Avatar
I just did my overhead console and i taped into the positive wire that goes to the dome light and i used the ground wire going to the dome light. It was Money on the first shot. I push the dome light button and the dome light comes on and not the map lights and i just push the map lights and they come on. Even when the truck is off they come on.
Turly56
Nov 13, 2015 01:00 AM
J.costello
Sep 25, 2015 05:31 PM
Lamartian92
Sep 10, 2015 09:27 PM
USMCvet0311
Aug 1, 2015 07:45 AM
So.cal Wrk Sled
Jul 26, 2015 12:10 AM
