? about putting sub in 04 LT truck with boss stereo
Old Dec 27, 2003 | 02:34 PM
02 black 5.3's Avatar
Default ? about putting sub in 04 LT truck with boss stereo
My buddy just got a 04 ext. cab silverado with every option including boss stereo and on-star if I put the sub under the rear seat,
1 can I hook it into the head unit or do I need to get a new one
2 do you need to do anything special to change the head unit, I have heard before that you can't cange the ones with on 03 and newer
3 doesn't the boss already have some kind of sub in it if so what sould be done with that
thanks for the info
Old Dec 27, 2003 | 06:38 PM
GREGGO's Avatar
thanks for the info
1. You will need a line level converter and a powered sub in order not to change the head unit and do it right without robing power elswhere.
2. The 03 and up stereos either need to relocated or a kit must be used.
3. Some do, some don't.
4. It's Bose, not boss. Boss is another aftermarket brand name that is pretty low end.
Old Dec 27, 2003 | 07:05 PM
CHAGO's Avatar
I'm not too sure what they did at the radio place, but I ran 2 10's with an amp off my factory head unit. No relocation of the head unit necessary
Old Dec 27, 2003 | 09:25 PM
KeukaZ71's Avatar
yes, it is possible to run an amp with subs off a factory headunit. need to splice into the rear speaker wires and route it to the amp. this usually takes the place of RCA cables. amps sometimes come with a wiring harness that plugs into the amp so you can attach the stock speaker wires to it. i heard the same thing about the 03+ trucks and their headunits too. not sure what is involved to get an aftermarket CD player in there
Old Dec 27, 2003 | 10:40 PM
ChevyTrukRacer99's Avatar
If you are using the On-Star option you can't change your head unit cause on star runs through the factory stereo, but like they said you can run a hi-lo convertor and hook up an amp and some subs.
Old Dec 28, 2003 | 06:50 PM
thanks
mzoomora
Jan 3, 2016 07:06 AM
wrb002
Aug 31, 2015 12:00 PM
black6spdz
Jul 16, 2015 01:32 AM
Nimoryan
Jul 5, 2015 03:50 PM
