4-High mod for 99
Old Nov 2, 2007 | 06:55 PM
ShaneSmith's Avatar
Default 4-High mod for 99
im wanting to do the 4-High headlight mod in my truck.
i want to have the foglights headlights and brights on when i turn my brights on..
which wires do i cut into and can someone post a picture or some kind of diagram please?
Old Nov 2, 2007 | 10:33 PM
COLDZ71's Avatar
Here is a link for you http://http://www.dieselplace.com/fo...ad.php?t=12804
Old Nov 3, 2007 | 03:45 AM
viciousknid's Avatar
Where's the Beef?
Don't cut anything, just do what this says.
https://www.performancetrucks.net/fo...=headlight+mod
Old Nov 3, 2007 | 03:41 PM
ShaneSmith's Avatar
Coldz71. that link doesnt work.
i did read the 4-hi mod thread though. It said i needed to cut the yellow wire running out of the light and ground it. but is the yellow wire on the driverside? and i didnt see how to keep the foglights on with the brights.. anyone know how to do that?
Old Nov 3, 2007 | 08:07 PM
496chevy's Avatar
that only works with 03+ trucks
clint
Old Nov 3, 2007 | 08:49 PM
Tootall's Avatar
for the lows and highs . . . . gound out the "grounds" on both sides of the low beams
Old Nov 4, 2007 | 02:41 PM
COLDZ71's Avatar
I copied this off the DieselPlace.
"Here's how I did it on my 02, no diode needed, will work for 01s also; Pull the underhood electrical center cover off, place aside. Unbold the four bolts holding the drivers side corner brace (fender to firewall) and remove. This is to remove the cover surround on the electrical center. Gently pry the plastic snaps holding it in place. There are two between it and the fender and two large hooks toward the passenger side at the bottom. Now lift off the plastic cover for the electrical center. You will see two clips holding the electrical center close to the fender side while the two toward the passenger side are hinges. Release the two by the fender and roll the electical center towards the passenger side. The mess of wires will tug a little but it will roll over to expose the underside. Looking at the right underside you will see a grey wire block. There are small letters and numbers identifying the wires. Look for D3 and you will find a yellow wire. This is the control for the low beams. Is is switched ground on the 01-02s unlike the 03-04s. All you need to do is get a scotchlock (or solder if you prefer) and tap the yellow wire to ground. I ran it in a loom up to the ground studs on the firewall (follow your underhood light wires down if you can't find one). That's it, test it out and fold the center back down. Recover and replace the brace"
Old Nov 4, 2007 | 03:53 PM
ShaneSmith's Avatar
thanks for the info.. now what about the fogs? anyone know how to have them on while the brights are on?
Old Nov 4, 2007 | 04:04 PM
COLDZ71's Avatar
I have not found a way to do it on a 99-02 trucks. The 03-07 have a different relay setup and you can use jumper wires and diodes to do all sorts of neat stuff.
Old Nov 19, 2007 | 12:33 PM
LJO's Avatar
LJO
Default 4 hi mod
COLDZ71 this mod worked like a charm. Anyone unsure of wiring need not fear. U can see the yellow wires run towards the front of the truck in a small loom that go to the headlights. Piece of cake. Just be certain to find a good ground otherwise you will not have low beams. I didn't even have to cut any wires. I just pulled the pin(two yellow wires) and soldered my extension wire to the side of the pin then applied heat shrink. This way it can be returned to stock later, if I want.
